I want to be able to change the header on a PL in a drawing using iLogic.
I'm able to "find" the PL(s) on a drawing but can't seem to figure out how to access the header propoertyy My goal to to change the header to show the P/N of the assembly/part it's created from.
My Current code is below:
doc=ThisDrawing.Document
oBOMs=doc.DrawingBOMs
For Each oBOM In oBOMs
MessageBox.Show("Found a PL", "Title")
Next oBom
In between the for/next loop is where I want to access the current BOM and change it's header depending on the related .iam/.ipt.
Any ideas?
Hi obourne,
Here is a quick example.
I hope this helps.
Curtis
oDocument = ThisDoc.Document Try 'look for the first parts list on the drawing Dim oPartsList As PartsList oPartsList = oDocument.ActiveSheet.PartsLists.Item(1) oPartsList.Title = "Hello World" Catch 'inform user no parts list was found MessageBox.Show("Parts List Not Found", "iLogic") End Try
Hello Curtis,
I am looking to use your code.
I also have additional parts Lists (tabulation) on the same drawing.
I would place the first part and attach the PL, then place another PL via the "browse" button.
How would I use this code to replace the PL title on a new PL, whenever a new PL is placed from browse?
I greatly appreciate any help you could provide.
Len
