I initially posted this in the Vault Customization forums by mistake.
I have tried everything I can think of but just cannot get this to work.
Has anyone else encountered problems with connecting to their Inventor Addins since moving to registry-free or Inventor 2014?
Gavin Bath
MFG / CAM Technical Specialist
Design and Motion Blog
Facebook | Twitter | LinkedIn | YouTube
Solved by philippe.leefsma. Go to Solution.
Try using a "dynamic" type for the automation interface. This works fine on my side.
Philippe.
Hi Philippe,
Thanks for your response.
Are you suggesting that I just add the "dynamic" keyword like below?
I tried this but get the same error. I'm wondering if maybe I have a problem with that test system.
Maybe I need to try building it on another machine.
Gavin Bath
Oops, didn't spot that I cast the AutomationInterface wrong there.
I'll try again
Gavin Bath
Thanks Philippe, that works! I realised I needed the dynamic keyword in the declaration and it appears to be working!
Well at least I'm onto the next bug anyway.....
Gavin Bath
