Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
CalculateStrokes generates a COM exception
3 REPLIES 3
serge2go
318 Views, 3 Replies
Here is my C# code:
private void Button1Definition_OnExecute(NameValueMap context)
try
// get current document
PartDocument oCurrentDoc = m_inventorApplication.ActiveDocument as PartDocument;
PartComponentDefinition oCompDef = oCurrentDoc.ComponentDefinition;
SurfaceBody body = oCompDef.SurfaceBodies[1];
if (body == null)
return;
int VertexCount, SegmentCount;
int[] VertexIndices;
double[] VertexCoordinates;
double v = body.get_Volume(90); // <---- returns fine
body.CalculateStrokes(.1, out VertexCount, out SegmentCount, out VertexCoordinates, out VertexIndices);
catch (Exception e)
System.Windows.Forms.MessageBox.Show(e.ToString());
The line:
ALWAYS generates a COMException 0x80020005 (Type mismatch). I am trying to figure out if my paramaters are wrong... Any help is greately appreciated.
Thank you.
-Serge
3 REPLIES 3
serge2go
in reply to: serge2go
I updated my copy of winodw 7 with all system updated (optional or not). I went ton Autodesk's website and dwonloaded Inventor 2013 SP2, installed it, no luck. I would really appreciate if someone would maybe take a lo look at the project.... If it is not something obvious with the code, then maybe the project settings??? But then again, I used the project wizzard with no specai modifications... Ayways, please let me know if I can provide you need more information.
Vladimir.Ananyev
Please use initialized arrays:
int VertexCount;
int SegmentCount;
int[] VertexIndices = {};
double[] VertexCoordinates = {};
       out VertexCount,
       out SegmentCount,
       out VertexIndices);
 This works for me.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
serge2go
in reply to: Vladimir.Ananyev
Wesome, that did it. Thank you.
