Inventor Customization
LiliaE
Message 1 of 4 (412 Views)
C# Print to PDF without PDF AddIn.SaveCopyAs
412 Views, 3 Replies
11-26-2012 06:00 AM
I would like to use Drag2PDF to create my PDF, and I want to automate the printing process. I want to print all sheets as a one PDF file. I have created a simple C# code, which prints to PDF, but I have one problem... When I submit the print a dialogue will appear (from the Drag2PDF) which asks for the file to be saved (location and name) How can I automate this?
I may not use pdfAddIn.SaveCopyAs, it makes my PDF not good.
public void PrintDrawingToPDF()
Inventor.DrawingPrintManager oPrintMgr = (Inventor.DrawingPrintManager)InventorOpen._invApp.ActiveDocument.PrintManager;
oPrintMgr.Printer = "Drag2PDF";
oPrintMgr.PaperSize = PaperSizeEnum.kPaperSizeA3;
oPrintMgr.PrintRange = PrintRangeEnum.kPrintAllSheets;
oPrintMgr.SubmitPrint();
ADN Support Specialist
adam.nagy
Message 2 of 4 (382 Views)
Re: C# Print to PDF without PDF AddIn.SaveCopyAs
12-11-2012 08:54 AM in reply to: LiliaE
Did you try DrawingPrintManager.PrintToFile() ?
Adam Nagy
Developer Technical Services
Autodesk Developer Network
LiliaE
Message 3 of 4 (374 Views)
12-11-2012 11:58 PM in reply to: adam.nagy
Hi
Yes I have tried DrawingPrintManager.PrintToFile(), but it gives not god result. It makes PDF file, which I cannot open afterward.
Lilia
adam.nagy
Message 4 of 4 (371 Views)
12-12-2012 12:53 AM in reply to: LiliaE
Just to avoid misuderstandings...
So you tried this and you could not open the pdf that this created?
oPrintMgr.PrintToFile("c:\\mypdf.pdf");
I'm asking because e.g. this worked fine for me in Inventor 2013 using VBA
Sub PrintTest()
    Dim dpm As DrawingPrintManager
    Set dpm = ThisApplication.ActiveDocument.PrintManager
    dpm.Printer = "Microsoft XPS Document Writer"
    dpm.PaperSize = kPaperSizeCSheet
    dpm.PrintRange = kPrintAllSheets
    dpm.PrintToFile "c:\my.xps"
End Sub
So if the exact same does not work with the Drag2PDF driver, then maybe there is some problem with that driver and you should contact its creator.
Cheers,
Adam Nagy
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
