First off I have a Assembly File Open and LOD set to "Mod" and I want to see the BomView for
Structured and I know you can only see the Structured Bom in LOD set to master. so I open another instance of the document (invisibly) in the Master representation and run code then I close the Document that I just opened invisible.
every thing works fine, then I do the same thing all over again and sometimes it works some times it throws an error and some times Inventor dies..so what is going on this this...see code below... and just FYI if I dont close the invisible Document then I can run the code over and over and over with no error..but I dont want to keep the invisible document open after i'm done with it..
Public Sub BomTest(ByVal InventorApp As Inventor.Application, ByVal oAssDoc As AssemblyDocument) Dim oAssemlyDocument As AssemblyDocument = Nothing Dim oAsmDocMasterLOD As AssemblyDocument = Nothing If InventorApp.ActiveEditDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then oAssemlyDocument = InventorApp.ActiveEditDocument Else oAssemlyDocument = oAssDoc End If Try If oAssemlyDocument.Dirty Then MsgBox("You Need to save the Assembly File First!") oAssemlyDocument = Nothing Exit Sub End If Catch ex As Exception MsgBox(ex.ToString) End Try Dim bClose As Boolean = False If oAssemlyDocument.LevelOfDetailName = "Master" Then oAsmDocMasterLOD = oAssemlyDocument Else Try oAsmDocMasterLOD = InventorApp.Documents.Open(oAssemlyDocument.File.FullFileName, False) bClose = True Catch ex As Exception bClose = False MsgBox(ex.ToString) End Try End If If oAsmDocMasterLOD IsNot Nothing Then Dim m_oBOM As BOM = oAsmDocMasterLOD.ComponentDefinition.BOM m_oBOM.StructuredViewEnabled = True m_oBOM.StructuredViewFirstLevelOnly = False m_oBOM.StructuredViewDelimiter = "." Dim m_oBOMView As BOMView = Nothing Try For Each oview As BOMView In m_oBOM.BOMViews If oview.ViewType = BOMViewTypeEnum.kStructuredBOMViewType Then Try m_oBOMView = oview Catch ex As Exception MsgBox("1. Error hit here") m_oBOMView = Nothing End Try Exit For End If Next Catch ex As Exception MsgBox("2. Error hit here") End Try If m_oBOMView IsNot Nothing Then Dim oBOMRows As Inventor.BOMRowsEnumerator = Nothing Try oBOMRows = m_oBOMView.BOMRows Catch ex As Exception MsgBox("3. Error hit here") oBOMRows = Nothing End Try If oBOMRows IsNot Nothing Then For Each row As Inventor.BOMRow In oBOMRows Try Dim sItemNumber As String = row.ItemNumber Catch ex As Exception MsgBox("4. Error hit here") Exit For End Try Next End If End If If bClose = True Then oAsmDocMasterLOD.Close(True) End If End If oAsmDocMasterLOD = Nothing oAssemlyDocument = Nothing End Sub
Could you please test Document.ReleaseReference method instead of Close method.
From API help:
This method releases the reference that gets added if a document is opened invisibly through the API. Releasing the reference on a hidden document makes it a candidate for closure the next time Inventor closes all unreferenced documents.
Let us know the result please.
That does stop the Error, thank you..but now i'm unable to save the current assembly. please see attached file
Is SaveAll command suitable in your workflow? If yes then you may try the following code
Dim oCommandMgr As CommandManager = oApp.CommandManager Dim oControlDef As ControlDefinition = oCommandMgr. _ ControlDefinitions.Item("AppSaveAllCmd") 'oApp.SilentOperation = True Call oControlDef.Execute() 'oApp.SilentOperation = False
thank you for your time spent looking in to this. All i'm really trying to do is access the Master Bill of Material so I decided to go with changing the LOD to Master is Needed. see code below. FYI i'm using Inventor 2012
Public Sub BomTest(ByVal InventorApp As Inventor.Application, ByVal oAssDoc As AssemblyDocument) If InventorApp Is Nothing Then Exit Sub End If If oAssDoc Is Nothing Then Exit Sub End If If InventorApp.ActiveEditDocument.DocumentType = DocumentTypeEnum.kAssemblyDocumentObject Then If oAssDoc IsNot InventorApp.ActiveEditDocument Then MsgBox("This Program was designed not to work in edit mode", MsgBoxStyle.Exclamation, InventorApp.Caption) Exit Sub End If End If Try If oAssDoc.Dirty Then MsgBox("The assembly must be saved before performing the Bill of Materials" & vbCrLf & "operation.", MsgBoxStyle.Exclamation, InventorApp.Caption) Exit Sub End If Catch ex As Exception MsgBox(ex.ToString) End Try Dim oCurrentLOD As LevelOfDetailRepresentation = Nothing Dim oRepMgr As RepresentationsManager = oAssDoc.ComponentDefinition.RepresentationsManager oCurrentLOD = oRepMgr.ActiveLevelOfDetailRepresentation InventorApp.StatusBarText = "Accessing Master Level Of Detail" InventorApp.ScreenUpdating = False Try If oAssDoc.LevelOfDetailName <> "Master" Then Dim oMasterLOD As LevelOfDetailRepresentation = oRepMgr.LevelOfDetailRepresentations.Item("Master") oMasterLOD.Activate(True) End If Catch ex As Exception oCurrentLOD = Nothing End Try If oAssDoc.LevelOfDetailName <> "Master" Then MsgBox("The Level Of Detail needs to be set to Master!") Else Try Dim m_oBOM As BOM = oAssDoc.ComponentDefinition.BOM m_oBOM.StructuredViewEnabled = True m_oBOM.StructuredViewFirstLevelOnly = False m_oBOM.StructuredViewDelimiter = "." Dim m_oBOMView As BOMView = Nothing For Each oview As BOMView In m_oBOM.BOMViews If oview.ViewType = BOMViewTypeEnum.kStructuredBOMViewType Then m_oBOMView = oview End If Next If m_oBOMView IsNot Nothing Then Dim oBOMRows As Inventor.BOMRowsEnumerator = m_oBOMView.BOMRows If oBOMRows IsNot Nothing Then For Each row As Inventor.BOMRow In oBOMRows Dim sItemNumber As String = row.ItemNumber Next End If End If Catch ex As Exception MsgBox("Unknown Error") End Try End If If oCurrentLOD IsNot Nothing Then If oRepMgr.ActiveLevelOfDetailRepresentation IsNot oCurrentLOD Then oCurrentLOD.Activate(True) End If End If InventorApp.ScreenUpdating = True oAssDoc = Nothing End Sub
