Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Batch Save Copy As PDF with a Custom Parameter Filename
2 REPLIES 2
YoniGaia
792 Views, 2 Replies
Hi All,
I urgently need the following:
An application that will let me choose a group of Drawing files (.idw) and perform "Save Copy As" to a PDF format on them. The Filename of each Drawing should be extracted from a custom Parameter I embeded in the IDW file.
I know I can use the Task Manager with a virtual PDF Printer to create these files, but then the PDF Filename will equal the IDW Filename, and I want it to be derived from the custom parameter I prepared inside the drawings.
Please advise.
Yoni
2 REPLIES 2
danny
in reply to: YoniGaia
in one of the blogpots of From the Trenches with Autodesk Inventor there is a post where you can find the code to export your drawings to a pdf with information like revnumber from your file. This for a start; the batching is also something I like to know.
ilogic-to-save-pdf-files-to-new
Danny
Regards
Danny
Inventor 2014 sp1 | Vault basic 2014 | HP Elitebook 8670W | win7 64b | 8Gb | GMT +1
YoniGaia
Thanks Danny,
Rule seems OK.
The trick is: How do I run it over a group of existing IDW files without having to open each file manually?
Yoni
