Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Basic Tolerance dimension - size of the box be adjusted?
1 REPLY 1
538 Views, 1 Reply
When a Basic Tolerance is used to dimension - can the size of the containing box be adjusted?
I understand this is set as a percentage of the text size - where is this value & can it be edited?
MES
1 REPLY 1
adam.nagy
HI,
Did you ask in the Product Support forum as well?
If this setting is not available in the UI then there is no API for it either. 😞
Cheers,
Adam Nagy
Autodesk Platform Services
