Here is a little trick how to set white Backgroung (for PrintSrceen for example) without changing ohter colour settings (like lines on the sketch):
Public Sub Background_Image()
ThisApplication.ActiveColorScheme.ImageFullFileName = "C:\Program Files (x86)\Autodesk\Inventor 2014\Backgrounds\white.png"
If ThisApplication.ColorSchemes.BackgroundType = kImageBackgroundType Then ThisApplication.ColorSchemes.BackgroundType = kGradientBackgroundType Else ThisApplication.ColorSchemes.BackgroundType = kImageBackgroundType End If Run_CMD ("AppAmbientShadowCmd") End Sub Function Run_CMD(ByVal cmd As String) As Boolean ' Get the CommandManager object. Dim oCommandMgr As CommandManager Set oCommandMgr = ThisApplication.CommandManager ' Get control definition for the line command. Dim oControlDef As ControlDefinition Set oControlDef = oCommandMgr.ControlDefinitions.Item(cmd) ' Execute the command. Call oControlDef.Execute End Function
My whie.png file is all white as you can imagine.
good luck
