BOM uppdate on drawing
4 REPLIES 4
montylowe
521 Views, 4 Replies
Having issues with my BOM not updating on my drawing after assembly has changed. Also I would like to make sure it stays sorted. I have a drawing templete the houses several views and an assembly that is changed via VB but when I open the drawing the views are updated but BOM is not. I have to do and edit and sort for the correct values to appear.
Thanks in advance.
4 REPLIES 4
montylowe
in reply to: montylowe
Does anyone have any light to shed or code to share regarding this Post? Thank
montylowe
OK maybe I haven't explained this very well. After I undate a assembly model I open the drawing and the BOM that I have on the drawing is not updated to the changeas that I have made only after I double pick the BOM and then close it does it reflect my changes is there a way to update iths thru the API
I hope someone can shed some light.
alewer
Use the DrawingDocument.Update method.
montylowe
in reply to: alewer
Found what I needed in the folowing Post.
By sorting the PartsList it Updates to current values
http://forums.autodesk.com/t5/Autodesk-Inventor/Parts-list-sorting/m-p/2767648
