I need to export our BOMs from inventor into a csv file that can be loaded into our ERP system. All of that code is working great and the help files were helpful in getting this completed. However it only will work if the assembly model is in the master level of detail!! This is not good at all since the only reason we use levels of detail is becasue our main level assemblys are 1000+ comp and our computers cant function with these levels of models in the master level of detail!! Is there anyway around this?
I guess I am confused by what you mean. It only works if the master level of detail is selected any other lod it does not recognize the bomquantiy object as having a structured level to export the bill.
