Does anyone know how to assign an keyboard shortcut to the, "Applications Options/Sketch/Autoproject edges during curve creation" setting?
I have a need to turn this on and off on a regular basis.
I have searched this forum and have found nothing that has delth with this.
Solved by Robert..F. Go to Solution.
By the way I relize that once a face is selected to sketch on that I can RMB and select Project Geometry, that is while in the sketch environment. I would like to be able to try a keyboard short cut to do the same thing.
You can create a macro in your application project like this:
Public Sub AutoEndgeProject() Dim oSketchOptions As SketchOptions Set oSketchOptions = ThisApplication.SketchOptions Dim b As Boolean b = False If Not oSketchOptions.AutoProjectEdges Then b = True oSketchOptions.AutoProjectEdges = b End Sub
Then you can apply a keyboard shotcut to it by clicking Tools->Customize going to the keyboard tab. Select macros in the Categories drop down. Find your macro in the list and then choose your keyboard shotcut
Robert:
This is great and I got a keyboard short cut to work, however the routine changes the "Autoproject edges during curve creation" rather than "Autoproject edges for sketch creation and edit".
Robert:
I just realized that my title was in reference to "Autoproject edges during curve creation" rather than "Autoproject edges for sketch creation and edit" which is what I wanted to do.
My bad.
