Hey there.
Can someone please give me a couple of pointers in creating a named sketch block (in an ipt) containing entities that I have created in the same sub?
Oh, and I'm doing this from Excel, in Inventor 2010.
What I have:
Function CreateUncutTagSketchBlock() Dim IVApp As Inventor.Application Dim oDoc As Document Dim oCompDef As ComponentDefinition Dim oSketch As Sketch Dim oTG As TransientGeometry Dim FileName As String Dim Coords(1 To 10) As Point2d Dim oSketchCircle As Circle2d Dim oSketchArcs(1 To 2) As Arc2d Dim oSketchLines(1 To 2) As SketchLine Dim oSketchBlockDef As SketchBlockDefinition Dim oArc As SketchEntity Dim oLine As SketchEntity Dim oCirc As SketchEntity Dim dRadius As Double Dim icounter As Integer Dim oSketchObjects As ObjectCollection Set IVApp = GetObject(, "Inventor.Application") Set oDoc = IVApp.ActiveDocument FileName = oDoc.FullFileName dRadius = 2.5 'On Error Resume Next If oDoc.DocumentType = kPartDocumentObject Then 'If oDoc.SketchActive = True Then 'check to ensure you have a sketch active Set oCompDef = oDoc.ComponentDefinition ' Set a reference to the component definition. Set oSketch = oCompDef.Sketches.Item(oCompDef.Sketches.Count) 'Set oSketchBlockDef = oDoc.ComponentDefinition.SketchBlockDefinitions.Add("UncutTag") ', oSketchObjects) Set oTG = IVApp.TransientGeometry Set Coords(1) = oTG.CreatePoint2d(0, 0) 'Circle centre (All co-ordinates in cm) Set Coords(2) = oTG.CreatePoint2d(0, 2.5) 'point on circle circumference Set Coords(3) = oTG.CreatePoint2d(-0.1, 2.2) ' Cutout: top left Set Coords(4) = oTG.CreatePoint2d(0.1, 2.2) ' Cutout: top right Set Coords(5) = oTG.CreatePoint2d(0.1, 1.8) ' Cutout: bottom right Set Coords(6) = oTG.CreatePoint2d(-0.1, 1.8) ' Cutout: bottom left Set Coords(7) = oTG.CreatePoint2d(-0.1, 2) ' Cutout: Left Arc centre Set Coords(8) = oTG.CreatePoint2d(0.1, 2) ' Cutout: Right Arc centre Set oTG = IVApp.TransientGeometry Call oSketch.SketchCircles.AddByCenterRadius(oTG.CreatePoint2d(0, 0), dRadius) With oSketch.SketchLines Set oSketchLines(1) = .AddByTwoPoints(Coords(3), Coords(4)) Set oSketchLines(2) = .AddByTwoPoints(Coords(5), Coords(6)) End With Call oSketch.SketchArcs.AddByCenterStartEndPoint(Coords(7), Coords(3), Coords(6), True) Call oSketch.SketchArcs.AddByCenterStartEndPoint(Coords(8), Coords(4), Coords(5), False) Set oSketchObjects = IVApp.TransientObjects.CreateObjectCollection For Each oArc In oSketch.SketchArcs Call oSketchObjects.Add(oArc) Next For Each oLine In oSketch.SketchLines Call oSketchObjects.Add(oLine) Next For Each oCirc In oSketch.SketchCircles Call oSketchObjects.Add(oCirc) Next Call oSketch.SketchBlocks("UncutTag").Add(oSketchObjects) Call oDoc.ComponentDefinition.SketchBlockDefinitions.Add("UncutTag", oSketchObjects) 'Call oSketch.SketchBlocks.AddByDefinition("UncutTag", oSketchObjects) ' test insertion/placement 'End If End If Set IVApp = Nothing Set oDoc = Nothing End Function
Please note that i've also taken a shortcut with the arcs, and the circle. I did try to create them using the same naming convention as the lines, but... I failed to implement it successfully.
Also, I can not quite figure out how to constrain all the start/end points together.
Any help you can give me will be greatly appreciated.
Rob.
Solved by philippe.leefsma. Go to Solution.
Hi Rob,
Below is a VBA sample that illustrates how to work with sketch blocks.
For your second questions, concerning the coincident constraints, the easiest way is to create SketchPoints out of the transient Point2d, then use those as input when you create sketch entities instead of passing directly the transient points. That way Inventor will automatically create a coincident constraint between the sketch entities, because they share the same SketchPoint object.
Public Sub CreateBlocks(doc As PartDocument) Dim tg As TransientGeometry Set tg = ThisApplication.TransientGeometry 'Create 1st sketch block definition. Dim def1 As SketchBlockDefinition Set def1 = doc.ComponentDefinition.SketchBlockDefinitions.Add("Block1") 'Draw the shape of this part as sketch geometry, (a rectangle with circles at the ends). Call def1.SketchLines.AddAsTwoPointRectangle(tg.CreatePoint2d(0, 0), tg.CreatePoint2d(12, 3)) Call def1.SketchCircles.AddByCenterRadius(tg.CreatePoint2d(1.5, 1.5), 0.5) Call def1.SketchCircles.AddByCenterRadius(tg.CreatePoint2d(10.5, 1.5), 0.5) 'Create 2nd sketch block definition. Dim def2 As SketchBlockDefinition Set def2 = doc.ComponentDefinition.SketchBlockDefinitions.Add("Block2") 'Draw the shape of this part as sketch geometry, (a square, with a circle in the middle). Call def2.SketchLines.AddAsTwoPointRectangle(tg.CreatePoint2d(0, 0), tg.CreatePoint2d(4, 4)) Call def2.SketchCircles.AddByCenterRadius(tg.CreatePoint2d(2, 2), 0.5) End Sub Public Sub DemoSketchBlocks() Dim doc As PartDocument Set doc = ThisApplication.ActiveDocument Dim tg As TransientGeometry Set tg = ThisApplication.TransientGeometry CreateBlocks doc 'Create a new part sketch based on XY Workplane Dim sketch As PlanarSketch Set sketch = doc.ComponentDefinition.Sketches.Add( _ doc.ComponentDefinition.WorkPlanes(3)) Dim def1 As SketchBlockDefinition Set def1 = doc.ComponentDefinition.SketchBlockDefinitions("Block1") Dim def2 As SketchBlockDefinition Set def2 = doc.ComponentDefinition.SketchBlockDefinitions("Block2") 'Add one instance of Block1 and 2 instances of Block2 Dim blk1 As SketchBlock Set blk1 = sketch.SketchBlocks.AddByDefinition( _ def1, tg.CreatePoint2d(0, 0)) Dim blk2 As SketchBlock Set blk2 = sketch.SketchBlocks.AddByDefinition( _ def2, tg.CreatePoint2d(2, 5)) Dim blk3 As SketchBlock Set blk3 = sketch.SketchBlocks.AddByDefinition( _ def2, tg.CreatePoint2d(10, 5)) Dim baseCircle1 As SketchCircle Set baseCircle1 = blk1.GetObject(def1.SketchCircles(1)) Dim baseCircle2 As SketchCircle Set baseCircle2 = blk1.GetObject(def1.SketchCircles(2)) Dim square1Circle As SketchCircle Set square1Circle = blk2.GetObject(def2.SketchCircles(1)) Dim square2Circle As SketchCircle Set square2Circle = blk3.GetObject(def2.SketchCircles(1)) 'Add coincident constraints between the circle center points. Call sketch.GeometricConstraints.AddCoincident( _ baseCircle1.CenterSketchPoint, square1Circle.CenterSketchPoint) Call sketch.GeometricConstraints.AddCoincident( _ baseCircle2.CenterSketchPoint, square2Circle.CenterSketchPoint) 'Ground the center point of one of the circle. Call sketch.GeometricConstraints.AddGround(baseCircle1.CenterSketchPoint) ThisApplication.ActiveView.Fit End Sub
Philippe.
Thank you, that has given me the pointers I needed, in both cases.
For the co-incident constraints, what I ended up doing was starting and finishing the lines from the start and end points of the arcs, rather than re-using the transient geometry points that I had created.
That is:
Call oSketchBlockDef.SketchArcs.AddByCenterStartEndPoint(Coords(7), Coords(3), Coords(6), True)
Call oSketchBlockDef.SketchArcs.AddByCenterStartEndPoint(Coords(8), Coords(4), Coords(5), False)
Call oSketchBlockDef.SketchLines.AddByTwoPoints(oSketchBlockDef.SketchArcs(1).StartSketchPoint, oSketchBlockDef.SketchArcs(2).EndSketchPoint)
Call oSketchBlockDef.SketchLines.AddByTwoPoints(oSketchBlockDef.SketchArcs(2).StartSketchPoint, oSketchBlockDef.SketchArcs(1).EndSketchPoint)
An example like you pasted, Philippe, would be very beneficial in the help files, which is very lacking in real-world examples for sketch-blocks.
