Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Automate DXF creation.
10 REPLIES 10
Message 1 of 11
dlsteg
1821 Views, 10 Replies
Is it possible to automate the creation of a DXF file when you save or check-in a part file from inventor. I have already set it up to create a DWF file to a shared folder on our network but we also export to DXF files as well for use in our machine shop. As of now the only way I know of doing it, is to open the .idw file and save it as a DXF manually. If anyone knows how to set this up to automatically create one on save or check-in please let me know.
Thank you,
- Darrin
10 REPLIES 10
Message 2 of 11
petercharles
in reply to: dlsteg
Just to be clear, is that a DXF of the Inventer PART, or a DXF of an Inventor drawing??
Message 3 of 11
in reply to: dlsteg
Yes, it's possible 🙂
See my code below
Sub DXF()
MsgBox "DXF-filer creating", vbInformation
Dim invApp As Inventor.Application
Set invApp = ThisApplication
' invApp.SilentOperation = True
Dim idwDoc As Inventor.DrawingDocument
Set idwDoc = invApp.ActiveDocument
Dim dxfFile As String
LaserDir = "c:\temp\"
NewDir = LaserDir + idwDoc.DisplayName + "\"
MkDir (NewDir)
dxfFile = LaserDir + idwDoc.DisplayName + "\" + idwDoc.DisplayName + ".dxf"
With invApp.CommandManager
Call .PostPrivateEvent(kFileNameEvent, dxfFile)
Call .StartCommand(kFileSaveCopyAsCommand)
End With
Set idwDoc = Nothing
'invApp.SilentOperation = False
Set invApp = Nothing
End Sub
Message 4 of 11
in reply to: dlsteg
why did you use the command manager? why not just call:
idwDoc.SaveAs dxfFile, True
Message 5 of 11
petercharles
in reply to: dlsteg
I still remain confused as why he needs to save a DXF version of his IDW for his machine shop?
Message 6 of 11
in reply to: dlsteg
It's needed for making cutplans, laser machine read DXF-files only
Message 7 of 11
petercharles
in reply to: dlsteg
Sorry, I didn't equate a machine shop with a laser which I associate with platework.
Of course, if it is a laser for platework that requires the DXF then this can be created automatically from the flat pattern by add-ins already in existance.
Message 8 of 11
in reply to: dlsteg
Take a look at my last blog posting where I discuss
translating files.  I use PDF in the example, but any file type follows the
same concepts.
Message 9 of 11
in reply to: dlsteg
Maybe you can tell any add-in for dxf creation?
Message 10 of 11
Alpha72
Broken Link
Message 11 of 11
Fredalone
question...
Where I put that code?
I wanna put an automatic save too...
like... hmm...
IDW to DXF
File -> SaveCopyAs -> DXF file /
" DXF Options -> AutoCad 2000 / LT 2000 DXF -> Full Scale (1:1) - Model Space "
I do this manually, but I wanna put the code to put this automaticly... Its possible?
Tags (3)
