Hi
How do I enable or add show/hide all constraints tool in status bar? I tried to hit F8 or F9 nothing happened.
In my status bar, I only see Snap to Grid, Tolerance, Slice Graphics, and Show All Degrees of Freedom. I am missing show all constraints tool. Where can I get that? I tried to open someone's file, it was there!! However, when I try to open a new file, it is not there.
This thread is a little old, but just in case you did not found your solution...
It seams to me that you sketch does not have contraints to show/hide. When the sketch is without any contraint, the F8-F9 key will do nothing and the button in the status bar will not appear. Try drawing some lines, apply contraints and your button or F8/F9 should work.
Hope this helps.
