Inventor Customization
Message 21 of 23 (103 Views)
Re: Autodesk 2013 iLogic issue with inputboxes
06-14-2012 11:03 PM in reply to: MegaJerk
Thank you so much! THAT is THE answer that I needed!
What I discovered now is that with the french culture (fr-FR), the point isn't allowed. But I checked the other culture available, and I found tha there is the swiss french culture (fr-CH) wich is the suitable language, and with it, the point work! It was all about that. Now, i don't understand why by default, the french french (if I can call it that way) is set. But anyway it doesn't matter! Thank you really much!
MegaJerk
Message 22 of 23 (96 Views)
06-15-2012 05:07 AM in reply to: voutilainen
You’re welcome! Also, the fr-FR should be set by default probably by what you have your Operating System (Windows in this case) set to. Cheers all around!
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
Message 23 of 23 (91 Views)
06-17-2012 10:52 PM in reply to: MegaJerk
That's what's strange. The OS is set on swiss french. But anyway, it doesn't matter, I think we can close this chapter on a happy ending. Thank you again.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
