Inventor Customization
Message 1 of 23 (386 Views)
Autodesk 2013 iLogic issue with inputboxes
386 Views, 22 Replies
05-24-2012 11:43 PM
Hi everybody, this is my second topic upon that issue. The first  one was here: http://forums.autodesk.com/t5/Autodesk-Inventor/iLogic-inputbox-only-decimal-value-with-coma-not-wit...
To resume the issue here, my problem is that I did, a couple of months ago, a part with a rule containing some input boxes. It worked without a bug and set it as a specific template, on Inventor 2012.
I tried to reuse it as a template without changing its rule on Inventor 2013. When the input box pops out and ask the value it needs, if I type "0.2" it says that "string's conversion "0.2" in a 'double' type isn't valid". But if I type "0,2" I have absolutely no problems.
And on the "more infos"  tab, I can see that message:
"System.InvalidCastException: La conversion de la chaîne "0.2" en type 'Double' n'est pas valide. ---> System.FormatException: Le format de la chaîne d'entrée est incorrect.
   à Microsoft.VisualBasic.CompilerServices.Conversions.ParseDouble(String Value, NumberFormatInfo NumberFormat)
   à Microsoft.VisualBasic.CompilerServices.Conversions.ToDouble(String Value, NumberFormatInfo NumberFormat)
   --- Fin de la trace de la pile d'exception interne ---
   à LmiRuleScript.Main()
   à Autodesk.iLogic.Exec.AppDomExec.ExecRuleInAssembly(Assembly assem)
   à iLogic.RuleEvalContainer.ExecRuleEval(String execRule) "
I work on:
Windows 7
Autodesk design suite premium 2013 french.
MegaJerk
Message 2 of 23 (381 Views)
Re: Autodesk 2013 iLogic issue with inputboxes
05-25-2012 05:36 AM in reply to: voutilainen
Does the code below error out for you, when you type in 0.2 ?
Dim iString As String
Dim iDoub As Double
'''/////////// Let's ask the user to type something in
iString = InputBox("Super String Converter-o-Matic 2012", "Strings --> Doubles!", "")
'''/////////// If the input can be succesfully considered a number, then we proceed
If IsNumeric(iString) = True Then
'''/////////// If it is a number, we'll set our variable 'iDoub' to equal the String, converted over
'''/////////// into a double
iDoub = CDbl(iString)
'''/////////// Now we show you the result
MessageBox.Show("Your Double Is :  " & iDoub, "Converted!")
Else
'''/////////// If the variable 'iString' can't be considered to have a numeric value, then we
'''/////////// tell the user that we can't convert their input
MessageBox.Show("We can't convert letters to numbers! We have standards!", "Not-Converted!")
End If
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
Message 3 of 23 (359 Views)
05-28-2012 10:54 PM in reply to: MegaJerk
Hi Megajerk, Thanks for your answer.
So It doesn't error me out, it says your message "We can't convert letters to numbers! We have standards!"
Makes me smile.
So  must I apply it to my code?
MegaJerk
Message 4 of 23 (350 Views)
05-29-2012 05:45 AM in reply to: voutilainen
Actually, if you're getting that message when  you type in 0.2 (zero point two), then there certainly is something wrong.
Try the following code and tell me the values that it returns back to you in the final box.
Dim oBlah,oLaLa As String
Dim oDarn As Char
oBlah = InputBox("Input your string", "String Detective", "")
For Each oDarn In oBlah
	If oLaLa = "" Then
		oLaLa = (Asc(oDarn))
		Else
		oLaLa = oLaLa & "," &  (Asc(oDarn))
	End If
Next
MessageBox.Show(oLaLa,"String Detective Has Found This!")
So when you run that code, type in your 0.2, and tell me what three numbers you get back.
Message 5 of 23 (347 Views)
05-29-2012 10:34 PM in reply to: MegaJerk
So the answer is: 48,46,50
MegaJerk
Message 6 of 23 (341 Views)
05-30-2012 05:04 AM in reply to: voutilainen
Well that’s what you should be getting. You may have a rather unique problem on your hand being that you’re input of 0.2 is producing the correct Ascii values (48,46,50), but the function ‘IsNumeric’ is refusing to accept that as a proper numeric value (despite the fact that it is).
Perhaps someone from Autodesk would be willing to dig deeper into this. Perhaps it’s a localization bug.
I’m sorry that I couldn’t be more useful.
Message 7 of 23 (335 Views)
05-30-2012 10:36 PM in reply to: MegaJerk
No problem, thanks for your time and help!
Message 8 of 23 (307 Views)
06-06-2012 10:41 PM in reply to: voutilainen
Hi again everybody, after looking a bit more on the web, it seems that this issue is not related to inventor, but to visual basic. Some people have the same kind of problem, but on other software. But I'm searching, and nobody seems to have a real solution. Could someone help me?
MegaJerk
Message 9 of 23 (302 Views)
06-07-2012 05:13 AM in reply to: voutilainen
Does the following code give you the "Unable to parse" or does it return a message box with the correct numerical value in it?
Dim value As String
Dim result As Decimal
value = "0.2"
If Decimal.TryParse(value, result)
   MessageBox.Show(result)
Else
   MessageBox.Show("Unable to parse:  " & value,"")
End If
(That is for ilogic)
Message 10 of 23 (296 Views)
06-07-2012 10:34 PM in reply to: MegaJerk
Unable to parse.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
