Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
Hope bleow VBA code can help you:
Sub FindPartFromAssembly() Dim oAssy As AssemblyDocument Set oAssy = ThisApplication.ActiveDocument Dim oCompDef As AssemblyComponentDefinition Set oCompDef = oAssy.ComponentDefinition Dim oOccus As ComponentOccurrencesEnumerator Set oOccus = oCompDef.Occurrences.AllLeafOccurrences Dim odoc As PartDocument Dim oOccu As ComponentOccurrence Dim oAttributeMgr As AttributeManager Dim oAttributeSets As AttributeSetsEnumerator For Each oOccu In oOccus Set odoc = oOccu.Definition.Document Set oAttributeMgr = odoc.AttributeManager Set oAttributeSets = oAttributeMgr.FindAttributeSets("NS_Lock") If oAttributeSets.Count <> 0 Then Dim oBrowserPane As BrowserPane Set oBrowserPane = oAssy.BrowserPanes("Model") Dim oNode As BrowserNode Set oNode = oBrowserPane.GetBrowserNodeFromObject(oOccu) Debug.Print oNode.FullPath Debug.Print odoc.FullDocumentName Exit For End If Next End Sub
Nacho
The VBA code does not set error checking, so you can add error checking to avoid the failure like below:
Sub FindPartFromAssembly() Dim oAssy As AssemblyDocument Set oAssy = ThisApplication.ActiveDocument Dim oCompDef As AssemblyComponentDefinition Set oCompDef = oAssy.ComponentDefinition Dim oOccus As ComponentOccurrencesEnumerator Set oOccus = oCompDef.Occurrences.AllLeafOccurrences Dim odoc As PartDocument Dim oOccu As ComponentOccurrence Dim oAttributeMgr As AttributeManager Dim oAttributeSets As AttributeSetsEnumerator On Error GoTo findnext: For Each oOccu In oOccus Set odoc = oOccu.Definition.Document Set oAttributeMgr = odoc.AttributeManager Set oAttributeSets = oAttributeMgr.FindAttributeSets("NS_Lock") If oAttributeSets.Count <> 0 Then Dim oBrowserPane As BrowserPane Set oBrowserPane = oAssy.BrowserPanes("Model") Dim oNode As BrowserNode Set oNode = oBrowserPane.GetBrowserNodeFromObject(oOccu) Debug.Print oNode.FullPath Debug.Print odoc.FullDocumentName Exit For End If findnext: Next End Sub
Hi
i have tried this code and i cannot get it to work. I have a different routine from the API that will get/set attributes. When i run this in the mail assembly, i can set an attribute to a part and get the attribute name back. I can also run the code in the sub assembly and do the same but i cannot get the attribute name from the part in the sub assembly. this is the code i am using from the API-
Public Sub SetAndGetAttribute() ' Select an entity. Dim oSelectedObject As Object Set oSelectedObject = ThisApplication.CommandManager.Pick(kAllEntitiesFilter, "Select an entity.") ' Make sure the selected object supports attributes by attempting ' to use the AttributeSets property of the object. Dim oAttribSets As AttributeSets On Error Resume Next Set oAttribSets = oSelectedObject.AttributeSets If Err Then MsgBox "The selected object does not support attributes." Exit Sub End If On Error GoTo 0 Dim sNewValue As String Dim oAttribSet As AttributeSet Dim oAttrib As Inventor.Attribute ' Check to see if the object already has an attribute set named "AttribTest". If oAttribSets.NameIsUsed("AttribTest") Then ' Get a reference to the existing attribute set. Set oAttribSet = oAttribSets.Item("AttribTest") ' Get a reference to the existing attribute. Set oAttrib = oAttribSet.Item("Attrib") ' Display the current value and allow the user to specify a new value. sNewValue = InputBox("Edit existing value", "Modify Existing Attribute", _ oAttrib.Value) ' If the value's different, change the value of the attribute. If sNewValue <> "" And sNewValue <> oAttrib.Value Then oAttrib.Value = sNewValue End If Else ' Get the value to assign to the attribute. sNewValue = InputBox("Specify attribute value", "Create Attribute") ' If a value was entered, create a new attribute set and attribute. If sNewValue <> "" Then ' Create a new attribute set with the name "AttribTest". Set oAttribSet = oAttribSets.Add("AttribTest") ' Create a new attribute named "Attrib" and assign the value. Set oAttrib = oAttribSet.Add("Attrib", kStringType, sNewValue) End If End If End Sub
when i run your code (with the AttributeSet names above, i cannot get a result at all 😞
Nigel
Nacho
