Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Attaching balloon
1 REPLY 1
766 Views, 1 Reply
Attaching balloon
I'm writing a program which attached a balloon to an existing balloon, such as the inventor command  "Attach balloon"
i'm almost there: User selects an existing balloon and a component and gives a direction to draw the balloon and then the balloon is created fine.
The only problem is that i can't connect my balloon to the base balloon. So when i move the base balloon the attached balloon doesn't move with it.
Does anybody know how to do this?
Geert
Code: (is part of a larger Auto ballooning program)
PrivateSub CreateAttachBalloon(ByVal oBalloon As Inventor.Balloon)
Try
     Dim oDrawDoc As Inventor.DrawingDocument
     oDrawDoc = m_inventorApplication.ActiveDocument
     Dim oActiveSheet As Inventor.Sheet
     oActiveSheet = oDrawDoc.ActiveSheet
    Dim oDrawingCurveSegment As Inventor.DrawingCurveSegment
    Dim oSelect AsNew clsSelect
    oDrawingCurveSegment = oSelect.Pick(Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter,
                 "Select curve in highlighted component!", Inventor.SelectionFilterEnum.kDrawingCurveSegmentFilter)
     Dim oDrawingCurve As Inventor.DrawingCurve
     oDrawingCurve = oDrawingCurveSegment.Parent
     Dim oTG As Inventor.TransientGeometry
     oTG = m_inventorApplication.TransientGeometry
     Dim oLeaderPoints As Inventor.ObjectCollection
     oLeaderPoints = m_inventorApplication.TransientObjects.CreateObjectCollection
     Dim dBalloonDiameter AsDouble
     dBalloonDiameter = oBalloon.Style.BalloonDiameter
     'user must give direction where to create the balloon
     Dim Direction AsInteger
     Dim oMouseEvent AsNew MouseEvents(oBalloon)
     DoWhile oMouseEvent.isDone = False
                m_inventorApplication.UserInterfaceManager.DoEvents()
                Direction = oMouseEvent.Direction
      Loop
     ' Create balloon center point.
       Select Case Direction
           Case 0
                   Call oLeaderPoints.Add(oTG.CreatePoint2d(oBalloon.Position.X + dBalloonDiameter,
                                   oBalloon.Position.Y - dBalloonDiameter / 2))
            Case 90
                   Call oLeaderPoints.Add(oTG.CreatePoint2d(oBalloon.Position.X, oBalloon.Position.Y +
            Case 180
                   Call oLeaderPoints.Add(oTG.CreatePoint2d(oBalloon.Position.X - dBalloonDiameter,
            Case 270
                   Call oLeaderPoints.Add(oTG.CreatePoint2d(oBalloon.Position.X, oBalloon.Position.Y -
                                  dBalloonDiameter * 1.5))
      End Select
      'Add the GeometryIntent to the leader points collection.
      'This is the geometry that the balloon will attach to.
      Dim oGeometryIntent As Inventor.GeometryIntent
      oGeometryIntent = oActiveSheet.CreateGeometryIntent(oDrawingCurve)
       Call oLeaderPoints.Add(oGeometryIntent)
       Dim oAttachBalloon As Inventor.Balloon
       oAttachBalloon = oDrawDoc.ActiveSheet.Balloons.Add(oLeaderPoints)
       'delete all leadernodes
       Dim oLeaderNode As Inventor.LeaderNode
       For Each oLeaderNode In oAttachBalloon.Leader.AllNodes
                oLeaderNode.Delete()
       Next
       'TODO: Attach balloon to base balloon
      Catch ex As Exception
     End Try
End Sub
1 REPLY 1
I already found it!
replace:
By:
Dim oBalloonValueSets As Inventor.BalloonValueSets = oBalloon.BalloonValueSets
Dim oBalloonValueSet As Inventor.BalloonValueSet = oBalloonValueSets.Add(oComponentOccurrence)
This will attach balloon!
