Assigning weight to downloaded part files
2 REPLIES 2
jlb1970
785 Views, 2 Replies
I typically need to download iges, step files for assemblies and would like to assign their actual weights to the respective parts. These weights are typically not in the iproperties because they are just surfaces.
Does anyone know how to assign specific weights to the general properties in the iproperties box?
2 REPLIES 2
BLHDrafting
in reply to: jlb1970
Go to the iProperties Physical tab and manually type the value into the Mass cell. Hit apply and Save. You will see a new icon appear adjacent ot he entered value. It shows a hand, as in manually changed.
Brendan Henderson
Web www.blhdrafting.com.au
Twitter @BLHDrafting
Windows 7 x64 -64 GB Ram, Intel Xeon E5-1620 @ 3.6 GHz
ATI FirePro V7800 2 GB, 180 GB SSD & 1 TB HDD, Inv R2016 PDSU SP1 (Build 210), Vault 2016 Professional Update 1 (Build 21.1.4.0)
You could override mass using MassProperties.Mass property.
MassProperties.MassOverridden property indicates if the mass value is overridden.
There are a pair of samples on mass properties in the Inventor API help.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
