Hello together,
how could I isolate the parts to a given constraint?
Thank you
Georg
In your model browser > expand the relationships folder > Go to the Contraint you want to isolate and select "Isolate Components"
Please let me know if this works
You probably mean isolate the occurrences to be accurate ... the command is doing nothing more than changing the visibility of affected occurrences by a certain constraint. Each constraint will return the affected occurrences, for example:
- MateConstraint.AffectedOccurrenceOne Property
- MateConstraint.AffectedOccurrenceTwo Property
To set the occurrence visibility, use ComponentOccurrence.Visible = false.
I hope it helps.
Philippe.
