I have one application that will run in a server and uses the ApprenticeServerComponent to change iProperties in Inventor files.
This application is a standalone application to run in a server and I don’t want install Inventor in that server.
What is the minimal ApprenticeServerComponent files installation to run my application?
It is enough select “Local Copy” in reference file “Autodesk.Inventor.Interop.dll” in my application?
If yes, the “Autodesk.Inventor.Interop.dll” is compatible with 32buts and 64bits?
Thanks & Regards,
Rui
Solved by rjay75. Go to Solution.
