Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
ApprenticeServerComponent error
22 REPLIES 22
Message 1 of 23
1793 Views, 22 Replies
I am getting the following error when using the ApprenticeServerComponent in C#:
"Retrieving the COM class factory for component with CLSID {C343ED84-A129-11D3-B799-0060B0F159EF} failed due to the following error: 80040154."
The error appears in the following line:
ApprenticeServerComponent oApprentice = new ApprenticeServerComponent();
22 REPLIES 22
Message 21 of 23
in reply to: adam.nagy
Hi Adam,
I have tested your code running the service under a local administrator user account:
And I get exactly the same error than before. I am not logged in windows with administrator.
What could be missing?
Thanks & Regards,
Rui
Message 22 of 23
With your 2nd suggestion "Copy all the Inventor COM object entries from the HKCU (Current User) section of the registry to the HKLM (Local Machine) one" don't give anymore the error in line
Now the error "Return argument has an invalid type." is in line
 foreach (PropertySet lcl_prprSet in invDoc.PropertySets)
 This error only appears when from a Windows Service.
Rui
Message 23 of 23
adam.nagy
What if you log in as an Administrator and then switch to a user. Does that make a difference?
Adam Nagy
Autodesk Platform Services
