Can anybody help??
I need an "addin" writing, for "AutoDesk Inventor" to run a VBA macro on either "SAVE" or "CLOSE" of a ipt, idw or iam file.
Is anybody interested in wirting the program for me?
If so can you please give me an indication of cost???
Thanks in advance!!!
Darren
Hello isocam,
I regularly write addins for companies.
Could you mail me a bit more details? info AT cadkunde DOT nl
Then I can be more specific about the costs
Kind Regards,
Arnold van der Veen
If you want to look into doing it yourself (the tutorials are fairly straight foreward) , it's pretty much done for you on Brian Ekins blog
Also, depending on the version of inventor you are running, this could be done very easily by using an external iLogic rule that runs a macro for you, I would recommend this as you are able to maintain / change the code yourself.
InventorVb.RunMacro("projectName", "moduleName", "macroName")
I think someone has already made an addin that allows you to choose macros to autorun. Cant remember where it is or what it was called so not very helpful, but I know it out in the internet somewhere 😉
If you really want an addin, let me know and I might be able to make one for you if you are using Inventor 2014/2015. Should only take a few minutes If it's just an autorun.
Regards, Matt.
