Solved by VdVeek. Go to Solution.
I'm trying to write this down, and when i have the time i create a Chronicle video. But see the attached part en image for more information.
Changing the sweep length directly is not possible but there is a way to do this. when you create a split on the sweep and animate the position of the split-plane you can animate the sweep length.
I hope this story makes sense, examine the part for more information.
I created a video for better understanding.
Rob.
I created a Chronicle video to show the steps for animating a sweep.
https://chronicle.autodesk.com/Main/Details/7f5f09c5-6fa0-4a5e-ac8c-038c8d0ce4f3
Rob.
In case someone on this thread is interested, I found a way to recreate this process for a 3D sketch to allow the sweep length paramenter to lead in all three dimensions. I basically followed these steps.
Hope this helps someone.
