Hi everyone,
Is the alpha sort function available trough API ? It's located in Assembly tab, Productivity tools. I'd like to use it in a custom program instead of asking my customer to click on the button.
Solved by Curtis_Waguespack. Go to Solution.
Hi aguitton116,
This should work:
‘AssemblyBonusTools_AlphaSortComponentsCmd:Alpha Sort Components ThisApplication.CommandManager.ControlDefinitions.Item("AssemblyBonusTools_AlphaSortComponentsCmd").Execute
I hope this helps.
Curtis
