Does anyone know how to add pre-defined text to a Selected Dimension with either iLogic or VBA?
I have to create lots of drawing with a lot of dimensions with the same wording.
The Layout is as follows:
<DIM> Maximum
Product Width
What I would like to do is select the Dimension, and then click and button on a form (or VBA USerform) that adds pre-defined text.
Has anyone been able to do this as it will make my life a lot simpler..
Solved by Vladimir.Ananyev. Go to Solution.
Did you find an answer to your question? I am needing the same functionality.
After manually setting the dimension text with a parameter reference I inspected the formatted text on the dimension object to be ...
"<DimensionValue/><Parameter Resolved='True' ComponentIdentifier='ValidPathToMyPart' Name='Dim_A' Precision='2'>53.75</Parameter>"
If I then set the formatted text value with that same string, I get an "automation error, Unspecified error". Maybe that isn't supported via the API?
George
I never managed to find a solution to this issue.
I also tried the method you have described, with the same results.
I have concluded that it is probably not possible to do this with the API; or if it is possible, I still don't know how to do it.
Thanks for your reply.
Does anyone know the "< />" code for GAUGE as a dimension text user parameter?
I see that "<DimensionValue/>" is for the dimension value, "<br/>" does a return to next line, <stack> does a stacked dimension, etc.
JCKCAD
