Hi, Iam still trying to figure out everything in inventor and came across this issure which I hope someone can help me with.
Iam trying to make a weldment be patterned.
I have a valveblock there the number of blocks is controlled by a user parameter pattern.
But 2 of the components in the pattern is welded together and I would like to have the weldment follow the numbers in the pattern without having to redo it everytime I change the user parameter.
I understand that it is not possible to directly pattern the weldment bread (HINT AUTODESK NEXT UPDATE 😉 in solidworks you can), but is there someway to make a ilogic rule to add weldments?
Hope to hear from some ilogic-genius
Kind Regards
Jens
Inventor Professional 2012
Vault Professional 2012
