I can't find any example of the topic. Added to that the fact that the CustomTables Add member uses SAFEARRAY and that CSafeArray in the SafeArrayUtil.h header tells me not to use CSafeArray any more...
!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!! This file is provided for backwards compatibility for existing clients only. !!! New clients should probably consider using the more robust CComSafeArray wrapper provided in ATL instead. !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
...is there an example using C++/COM of creatng a CustomTable in an IDW?
In this fragment I'm unsure of how to init the pColumnTitles and the TableWidths and TableHeights...
SAFEARRAY* pColumnTitles = new SAFEARRAY ; CComPtr<CustomTables> pCustomTables = nullptr ; pSheet->get_CustomTables (&pCustomTables) ; CComPtr<Point2d> ptTable; // Create a 2d point theApp.GetTransGeomPtr()->CreatePoint2d(0.0,0.0,&ptTable); const int ikNumCols = 3 ; const int ikNumRows = 6 ; CComPtr<CustomTable> pCustomTable = nullptr ; pCustomTables->Add (L"HOLES",ptTable,ikNumCols,ikNumRows,&pColumnTitles,TableWidths,TableHeights,varEmpty,&pCustomTable) ;
Solved by oransen. Go to Solution.
I've managed to drag myself ahead a bit, as follows:
wchar_t* ColNames[128] = {L"Column One",L"Column Two",L"Column Three"}; SAFEARRAY* pstrColumns = CreateSafeStringArray(3, ColNames); CComPtr<CustomTables> pCustomTables = nullptr ; pSheet->get_CustomTables (&pCustomTables) ; CComPtr<Point2d> ptTable; // Create a 2d point theApp.GetTransGeomPtr()->CreatePoint2d(10.0,10.0,&ptTable); const int ikNumCols = 3 ; const int ikNumRows = 6 ; /*double Widths[] = {10,10,10} ; SAFEARRAY* pWidths = CreateSafeDoubleArray(3, Widths) ; double Heights[] = {10,10,10} ; SAFEARRAY* pHeights = CreateSafeDoubleArray(3, Heights) ;*/ CComVariant varEmpty ; CComPtr<CustomTable> pCustomTable = nullptr ; pCustomTables->Add (CComBSTR(L"HOLES"),ptTable,ikNumCols,ikNumRows,&pstrColumns, varEmpty, // contents? varEmpty, // widths? varEmpty, // heights? varEmpty, // more info &pCustomTable) ; // table returned SafeArrayDestroy (pstrColumns) ; return true ;
and
SAFEARRAY* CreateSafeStringArray(long nElements, TCHAR *elements[]) { SAFEARRAYBOUND saBound[1]; saBound[0].cElements = nElements; saBound[0].lLbound = 0; SAFEARRAY *pSA = SafeArrayCreate(VT_BSTR, 1, saBound); if (pSA == NULL) { return NULL; } for (int ix = 0; ix < nElements; ix++) { BSTR pData = SysAllocString(elements[ix]); long rgIndicies[1]; rgIndicies[0] = saBound[0].lLbound + ix; HRESULT hr = SafeArrayPutElement(pSA, rgIndicies, pData); } return pSA; }
It works, but what do I need to pass for Contents, Widths and Heights in the call to Add?
And can any experts see any problems with my COM SAFEARRAY code?
