Inventor Customization
santoshr0114
Message 1 of 21 (889 Views)
Add-In not loading in Windows 7 64-bit OS
889 Views, 20 Replies
07-05-2012 03:58 AM
Hi Guys,
Already this post might be posted but i did not find any solutions on the internet. This might also seem a silly problem for you.
I have a bit of problem. I have created a Addin for Inventor using Visual Studion 2010 Professional.
My Addin Works fine for
Windows XP Professional Service Pack 3 (64-bit OS)
With Autodesk Inventor Professional 2012, 32-Bit Edition
Now I need to Deploy the addin on another Machine with below configuration,
Windows 7 Professional Service Pack 1(64 bit OS)
Autodesk inventor Professional 2012, 64-Bit Edition.
I tried to load my addin, it doesnot load, I tried to load it manually by Goint to Tools->Add-In and selecting my addin and selected "Loaded", Even then its not loading..
I am struggling to get this done.
Plz..Plz...Please guys let me know if there is any solution for this.
Thank You
Regards
Santosh
krieg
Message 2 of 21 (888 Views)
Re: Add-In not loading in Windows 7 64-bit OS
07-05-2012 05:28 AM in reply to: santoshr0114
Hello
Try to start your AddIn from VS and debug the Activate-Sub. Somewhere there it fails. Or add following to the Activate-Sub
Public Sub Activate(ByVal oAddInSiteObject As Inventor.ApplicationAddInSite, ByVal bFirstTime As Boolean) Implements Inventor.ApplicationAddInServer.Activate
            Try
' Put in all of your code here
Catch ex As Exception
                System.Windows.Forms.MessageBox.Show(ex.Message & vbNewLine & vbNewLine & ex.ToString)
            End Try
        End Sub
 Maybe the displaying error message indicates what's going wrong.
santoshr0114
Message 3 of 21 (887 Views)
07-05-2012 05:35 AM in reply to: krieg
Hi Krieg,
I have already tried this, there is not error at all. I have also used breakpoints, The execution wont stop.it will finish the whole execution and loads the inventor, but not the addin.
Is there any  other solution for this.
Thank You
Regards
Santosh
bsee1
Message 4 of 21 (883 Views)
07-05-2012 07:07 AM in reply to: santoshr0114
Are you using registry free addins, or are you using the older style registry dependent addins?
If using the registry free version, post the file location of the dll file, then upload the .addin file.  It may help to determine the problem.  (the .addin is just an xml file. it has no information you'd need to worry about sharing)
Win7 x64 - 16gb ram
i7 3610qm
FirePro M4000
Inventor 2013
ETO 6.1
santoshr0114
Message 5 of 21 (869 Views)
07-05-2012 09:35 PM in reply to: bsee1
I am using Register dependent Addin.
While creating and addin there is a template in Visual Studio to create "Autodesk Inventor Addin". I am using this template to create a addin. Once i finish my coding for inventor i just change from debug mode to release mode and copy the dll and the xml file to the Bin folder of inventor installation path. And paste the Addin to the C:\Application data\Autodesk\Addin\.
Thats all i do...
Actually i beginning my career in Customization.
Please provide any solution for this, many of you might solved this
Thank You
Regards
Santosh
bsee1
Message 6 of 21 (857 Views)
07-06-2012 04:33 AM in reply to: santoshr0114
From the description, that sounds more like registry free.
If you're sure it's registry dependent, make sure you use the proper registry command.
  • C:\Windows\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe
  • C:\Windows\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe
Since you're using 64bit, you'd need to use the bottom one when you register your addin.
Win7 x64 - 16gb ram
i7 3610qm
FirePro M4000
Inventor 2013
ETO 6.1
santoshr0114
Message 7 of 21 (862 Views)
07-06-2012 05:02 AM in reply to: bsee1
How to use it, can you please provide steps.
Thank You
Regards
Santosh
bsee1
Message 8 of 21 (862 Views)
07-06-2012 05:08 AM in reply to: santoshr0114
To register a new addin, enter this into the command line. Make sure to specify the full path to the dll file and the name of your addin.  Again, this is only if you're using a registry dependent addin.
C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /codebase "C:\Program Files\yourFilePathHere\addinName.dll"
To unregister:
C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /unregister "C:\Program Files\yourFilePathHere\addinName.dll"
Win7 x64 - 16gb ram
i7 3610qm
FirePro M4000
Inventor 2013
ETO 6.1
santoshr0114
Message 9 of 21 (860 Views)
07-06-2012 07:32 AM in reply to: bsee1
I am getting this message if i try to register or unregiter
C:\Windows\Microsoft.NET\Framework64\v2.0.50727>RegAsm/codebase "C:\Program File
s\Autodesk\Inventor 2012\Bin\Modified.dll"
Microsoft (R) .NET Framework Assembly Registration Utility 2.0.50727.5420
Copyright (C) Microsoft Corporation 1998-2004. All rights reserved.
RegAsm : error RA0000 : Failed to load 'C:\Program Files\Autodesk\Inventor 2012\
Bin\Modified.dll' because it is not a valid .NET assembly
Thank You
Regards
Santosh
bsee1
Message 10 of 21 (866 Views)
07-06-2012 07:42 AM in reply to: santoshr0114
Alright. I'm beginning to run out of ideas.
In Visual Studio, could you take a screenshot of the project "Application" tab with the "Assembly Information" showing as well??
Also, under build events, do you have anything in the post-build event command line?
Win7 x64 - 16gb ram
i7 3610qm
FirePro M4000
Inventor 2013
ETO 6.1
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
