I followed the instructions in Brian Ekins' instructions. http://modthemachine.typepad.com/files/VBAtoAddIn.pdf
It all worked well until I tried looking for the add-in in Inventor.
Page 6:
"Congratulations, you’ve just created an Add-In. Click the Build AUAddIn command (or the name or your Add-In) in the Build menu. Once it’s finished building, start Inventor and look in the Add-In Manager where you should see your Add-In in the list."
I am running Windows XP64. Let me know what you think!
The problem is that you're running on a 64-bit system. Visual Studio is registering the add-in as a 32-bit add-in so Inventor isn't finding it. I need to do a bit of research to see how/if you can tell visual studio to register it for 64-bit. It's easy to register it yourself from the command window for 64-bit. Here's the line to register a 32-bit add-in.
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe /codebase AddInName.dll
and here's the line to register a 64-bit add-in.
C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /codebase AddInName.dll
The difference being that the RegAsm for the 64-bit version is in the Framework64 directory. If you manually register your add-in, my guess is that it will now show up in the add-in manager.
Thanks Brian,
I tried registering the Add-In manually
I went to Start > Run, and entered the following line:
C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\Re gAsm.exe /codebase AUAddIn.dll
As you suspected, the addin did not show up in the Inventor Add-In list.
@ewcler wrote:
Thanks Brian,
Did you mean to say that it "did show up" rather than "did not show up"?
It did not show up in the add in manager. I attached a screen shot for reference. I see how my response was confusing.
I'm sorry to revive this topic, but I'm having the same issue. Can't figure out how to make inventor recognize my add-in.
Using Inventor 2010, VB.Net 2008 and Windows 7 Ultimate 64 bits.
Already tried registering with Regasm.exe in /Framework64/ but it didn't work.
Thanks in advance!
Fernando,
"Cooling & Freezing" Carton Freezers and Industrial Refrigeration
Duh, figured it out 😃
**** newbie error!
It is in fact very easy, just don't forget to include full path name when registering.
RegAsm.exe \codebase "C:\Program Files\xxxx\YourAddIn.dll"
OK, I'm very sorry to have revived this topic and a few minutes later, discovering by myself the solution, but it seems to me that asking the question by itself makes my brain work better and find the answer easier.
Thanks anyway, you may delete my posts if you like.
