Inventor Customization
Active Contributor
ewcler
Message 1 of 7 (407 Views)
Add In NOOB. Trying to get an add-in to show up using Visual basic 2008 express
407 Views, 6 Replies
07-15-2010 02:20 PM
I followed the instructions in Brian Ekins' instructions.  http://modthemachine.typepad.com/files/VBAtoAddIn.pdf
It all worked well until I tried looking for the add-in in Inventor.
Page 6:
"Congratulations, you’ve just created an Add-In. Click the Build AUAddIn command (or the name or your Add-In) in the Build menu. Once it’s finished building, start Inventor and look in the Add-In Manager where you should see your Add-In in the list."
I am running Windows XP64.  Let me know what you think!
Ed
Paul's Machine & Welding Corp.
Dell Precision T3600- Xeon E5-1620 @ 3.6 GHz 32GB Ram - Nvidia Quadro 4000 Windows 7
ADN Support Specialist
ekinsb
Message 2 of 7 (405 Views)
Re: Add In NOOB. Trying to get an add-in to show up using Visual basic 2008 exp
07-15-2010 06:03 PM in reply to: ewcler
The problem is that you're running on a 64-bit system.  Visual Studio is registering the add-in as a 32-bit add-in so Inventor isn't finding it.  I need to do a bit of research to see how/if you can tell visual studio to register it for 64-bit.  It's easy to register it yourself from the command window for 64-bit.  Here's the line to register a 32-bit add-in.
C:\WINDOWS\Microsoft.NET\Framework\v2.0.50727\RegAsm.exe /codebase AddInName.dll
and here's the line to register a 64-bit add-in.
C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\RegAsm.exe /codebase AddInName.dll
The difference being that the RegAsm for the 64-bit version is in the Framework64 directory.  If you manually register your add-in, my guess is that it will now show up in the add-in manager.
Brian Ekins
Developer Technical Services
Autodesk Developer Network
Active Contributor
ewcler
Message 3 of 7 (395 Views)
07-16-2010 07:07 AM in reply to: ekinsb
Thanks Brian,
I tried registering the Add-In manually
I went to Start > Run, and entered the following line:
C:\WINDOWS\Microsoft.NET\Framework64\v2.0.50727\Re gAsm.exe /codebase AUAddIn.dll
As you suspected, the addin did not show up in the Inventor Add-In list.
Ed
ekinsb
Message 4 of 7 (389 Views)
07-16-2010 10:21 AM in reply to: ewcler
ewcler wrote:
Thanks Brian,
Did you mean to say that it "did show up" rather than "did not show up"?
Brian Ekins
Active Contributor
ewcler
Message 5 of 7 (385 Views)
07-16-2010 11:42 AM in reply to: ekinsb
It did not show up in the add in manager.  I attached a screen shot for reference.  I see how my response was confusing.
Ed
Member
Fzigunov
Message 6 of 7 (275 Views)
12-20-2010 04:42 PM in reply to: ewcler
I'm sorry to revive this topic, but I'm having the same issue. Can't figure out how to make inventor recognize my add-in.
Using Inventor 2010, VB.Net 2008 and Windows 7 Ultimate 64 bits.
Already tried registering with Regasm.exe in /Framework64/ but it didn't work.
Thanks in advance!
Fernando,
"Cooling & Freezing"  Carton Freezers and Industrial Refrigeration
Member
Fzigunov
Message 7 of 7 (273 Views)
12-20-2010 04:53 PM in reply to: Fzigunov
Duh, figured it out =)
**** newbie error!
It is in fact very easy, just don't forget to include full path name when registering.
RegAsm.exe \codebase "C:\Program Files\xxxx\YourAddIn.dll"
OK, I'm very sorry to have revived this topic and a few minutes later, discovering by myself the solution, but it seems to me that asking the question by itself makes my brain work better and find the answer easier.
Thanks anyway, you may delete my posts if you like.
You are not logged in.
Ask the Community
Inventor Exchange Apps
Connect with Inventor
Twitter
Facebook
Blogs
Pinterest
Youtube
