Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Access inventor button icon
4 REPLIES 4
396 Views, 4 Replies
I am trying to build a treenode imagelist with some button icons.  I have a been able to convert an IpictureDisp to image.  So if I convert an image to a IPictureDisp, I can convert it back to an image.  However, if I try to get the icon as IpicturDisp (.StandardIcon) through a command control definition, it does not work.  Can we access the icon after the button has been defined and how ?
4 REPLIES 4
adam.nagy
Are you trying to do that from an AddIn or from outside another exe?
If the latter, then that will probably not work:
http://forums.autodesk.com/t5/Inventor-Customization/Error-adding-image-to-ImageSet/td-p/3271651
Cheers,
Adam Nagy
Autodesk Platform Services
in reply to: adam.nagy
Hi Adam,
              I am doing this with an VB.net addin - on Windows 7 on a 64 bit machine - Inventor 2015.
 I can access the .StandardIcon property for the button, splitbutton, splitbutton MRU and popup button control definitions but when I am trying to get the icon from a Toggle Pop-up control I get an error.  I have simplified my code to in the following manner so it is maybe easier to understand what I am doing wrong :
    Sub GetIcon(ByVal oCommand As Inventor.ControlDefinition)
        If oCommand.ControlType = ControlTypeEnum.kTogglePopupControl Then
            Dim oIcon As stdole.IPictureDisp
            oIcon = oCommand.StandardIcon  ' ****  This will generate the error #91 : object variable not defined
        End If
    End Sub
adam.nagy
Hi Carl,
It seems that not all Ribbon items have a valid control definition object, and even if they do they might not provide an icon - I guess because they are not a real ControlDefinition, they are just placeholders, not associated to a command that could actually be run.
http://adndevblog.typepad.com/manufacturing/2014/07/get-ribbon-images.html
Cheers,
Adam Nagy
NachitoMax
Hi
Funnily nough, I came across this about 3 minutes before seeing your post. NOTE: I wasn't looking to do this, just saw a post and looked at it out of interest.
Anyway, this might help 🙂
Nige
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
