Is there an API to check if DWG file is AutoCAD or Inventor DWG file?
I have tried using API GetIsInventorDWG() but it always returns value of VARIANT_TRUE.
I am is using COM (C++).
Thanks and Best Regards,
Vaibhav Kale
Solved by philippe.leefsma. Go to Solution.
I recall you need to use FileManager.IsInventorDWG Method, so the file hasn't been opened yet in Inventor.
Philippe.
Thanks for the usggestion Philippe!.
FileManager.IsInventorDWG Method works correctly.
