Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
API - save as FLAT PATTERN
2 REPLIES 2
866 Views, 2 Replies
Hello!
I was just wondering if anyone knows how to return to Folded part after creation of flat pattern using API code?
The code I have is straight forward, it saves dxf of the flat pattern if its exists, if flat pattern doesn`t exist it creates it and leaves the active ipt part as flat pattern on the screen.
    Private Sub SaveDXF()
        'Dim _inventorApplication As Inventor.Application
        ' get file name
        Dim pName As String
        pName = m_inventorApplication.ActiveDocument.DisplayName
        MsgBox(pName)
        ' Get the active document.  This assumes it is a part document.
        Dim oDoc As PartDocument
        oDoc = m_inventorApplication.ActiveDocument
        ' Save the current silent operation state.
        Dim silentState As Boolean
        silentState = m_inventorApplication.SilentOperation
        ' Get the DataIO object.
        Dim oDataIO As DataIO
        oDataIO = oDoc.ComponentDefinition.DataIO
        ' Build the string that defines the format of the DXF file.
        Dim sOut As String
        sOut = "FLAT PATTERN DXF?AcadVersion=R12&InvisibleLayers=IV_UNCONSUMEND_SKETCHES;IV_ALTREP_BACK;IV_ALTREP_FRONT;IV_ARC_CENTERS;IV_TOOL_CENTER_DOWN;IV_TOOL_CENTER;IV_TANGENT;IV_BEND;IV_BEND_DOWN"
        ' Create the DXF file.
        oDataIO.WriteDataToFile(sOut, FolderPath & "\" & pName & ".dxf")
        oDoc.Update()
    End Sub
after running the code above
So my question is how to perform GOTO FOLDED PART command through API? So its shows folded part ?
Thank you!
2 REPLIES 2
humbertogo
 with the FlatPattern.ExitEdit Method
something like
osheetMetalCompDef.Unfold() 'Go to flat pattern
osheetMetalCompDef.FlatPattern.ExitEdit() 'Go to folded part
in reply to: humbertogo
Thank you kind man!
