I am curently trying to do check in file to Vault. I do not want to use "Execute" (buttonclick ) method (the amount of file is large and this method is not reliable). The task is to corectly pass the arguments to the method
Function CheckinFile(
file As Autodesk.DataManagement.Client.Framework.Vault.Currency.Entities.FileIteration,
comment As String,
keepCheckedOut As Boolean,
associations() As Autodesk.Connectivity.WebServices.FileAssocParam,
bom As Autodesk.Connectivity.WebServices.BOM,
copyBom As Boolean, newFileName As String,
classification As Autodesk.Connectivity.WebServices.FileClassification,
hidden As Boolean,
Optional filePath As Autodesk.DataManagement.Client.Framework.Currency.FilePathAbsolute = Nothing)
So do you have code to get associations and bom from document using Inventor API or Apprentice?
