Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
A global transient geometry object?
8 REPLIES 8
Message 1 of 9
oransen
952 Views, 8 Replies
I've found myself using this code often:
// Get the transient geometry object. We'll use this to create pure geometry
CComPtr<TransientGeometry> pTrGeom;
pTrGeom = pApp->TransientGeometry;
But I was thinking, once I have pTrGeom can I just declare a global to hold it while my Inventor instance is running?
Alternatively I suppose I could have a global function which does this:
CComPtr<TransientGeometry> GetTransientGeometryPtr()
    static CComPtr<TransientGeometry> pTrGeom = NULL ;
if (pTrGeom == NULL) pTrGeom = pApp->TransientGeometry; return (pTrGeom) ; }
 So it reduces to a one-liner. But in COM is that static valid? I know the code is not complete above, but you get the idea.
What do other C++ COM programmers do here...?
8 REPLIES 8
Message 2 of 9
xiaodong_liang
in reply to: oransen
Both are fine to me. I perfer to defining it as global directly. It would look more clear.
Message 3 of 9
oransen
in reply to: xiaodong_liang
Could you give me an example of how you do that?
Because when I do it I get an exception when I exit from my program.
It seems as if it is not being released properly or maybe released twice, but I'm not COM expert enough to understand the error.
Message 4 of 9
jdkriek
What is the exception/error you are getting?
Jonathan D. Kriek
MFG Solutions Engineer
KETIV Technologies, Inc.
Message 5 of 9
oransen
in reply to: jdkriek
Here is the code, I'm new to COM so there may be a supid error in here:
#include "stdafx.h"
HRESULT ConnectToInventor (CComPtr<Application>& pInvApp)
    CLSID InvAppClsid;
    HRESULT hRes = CLSIDFromProgID (L"Inventor.Application", &InvAppClsid);
    if (FAILED(hRes)) {
        pInvApp = nullptr ;
        return hRes ;
    // See if Inventor is already running...
    CComPtr<IUnknown> pInvAppUnk;
    hRes = ::GetActiveObject (InvAppClsid, NULL, &pInvAppUnk);
    if (FAILED (hRes)) {
        // Inventor is not already running, so try to start it...
        wprintf (L"Could not get hold of an active Inventor , will start a new session\n") ;
        hRes = CoCreateInstance (InvAppClsid, NULL, CLSCTX_LOCAL_SERVER, __uuidof(IUnknown), (void **) &pInvAppUnk);
        if (FAILED (hRes)){
            pInvApp = nullptr ;
            return hRes ;
    // Get the pointer to the Inventor application...
    hRes = pInvAppUnk->QueryInterface (__uuidof(Application), (void **) &pInvApp);
    if (FAILED(hRes)) {
        return hRes ;
    return hRes ;
CComPtr<TransientGeometry> pTransGeom = nullptr ;
void InitTransGeomPtr(CComPtr<Application>& pInvApp)
    HRESULT hRes = pInvApp->get_TransientGeometry(&pTransGeom);
CComPtr<TransientGeometry> GetTransGeomPtr ()
    if (pTransGeom == nullptr) {
        wprintf (L"You have not called InitTransGeomPtr\n") ;
    return (pTransGeom) ;
static void DoInventorTest ()
    CComPtr<Application> pInvApp ;
    HRESULT hRes = ConnectToInventor (pInvApp) ;
    if (FAILED(hRes)) {
        wprintf (L"*** Failed to connect to Inventor application ***\n");
        return ;
    InitTransGeomPtr (pInvApp) ;
    wprintf (L"Hit a key") ;
    _getwch() ;
int _tmain(int argc, _TCHAR* argv[])
	HRESULT Result = CoInitialize (NULL);
	if (SUCCEEDED(Result))
		DoInventorTest();
	CoUninitialize();
	return 0;
 When I exit from the program I get the exception shown in the attacched screenshot.
All I want to do is be able to have a single transient geometry object/pointer which I init at the start and use throughout the program.
Maybe I'm missing a Release or delete or....
Message 6 of 9
adam.nagy
I think it would be a good idea to release the pointer before calling CoUninitialize() - i.e. release the pTransGeom pointer at the end of DoInventorTest(), otherwise the release is only called implicitly when _tmain is returning since the variable is declared globally.
Cheers,
Adam Nagy
Autodesk Platform Services
Message 7 of 9
oransen
in reply to: adam.nagy
I thought it could be a "ignorance of com" problem. But how do you release the pointer? the compiler says it is a private function:
InvSupp.cpp(320): error C2248: 'ATL::_NoAddRefReleaseOnCComPtr<T>::Release' : cannot access private member declared in class 'ATL::_NoAddRefReleaseOnCComPtr<T>'
Message 8 of 9
adam.nagy
Message 9 of 9
oransen
I've had a similar problem with the pointer to the Inventor app, it was resolved by setting it to NULL. When I have time I'll try the same with the global transient geometry pointer...
