After installing 3ds Max 2011, I got a problem with the activation of the product. First, a white screen showed, but after reading posts in this forum I found that the solution was to disable my Internet connection.
However, a second problem appears when I introduce the Activation code I got form Autodesk. It is a script error, very similar to the one described here: http://forums.autodesk.com/t5/Installation-Licensing/License-Manager-Script-Errors/m-p/2670531/highl...
I tried changing users but it doesn't work.
Attached is a screenshot of the error (sorry, it is in spanish).
If you are using Internet explorer 8 try downgrading to IE7
also try resetting the IE security settings.
there are some other pointers regarding this issue on IE
http://forums.techarena.in/technology-internet/1210516.htm
Did you try as a true administrator of the machine
I am using IE7and I am running as the Admin account.
I read the disscusion you sent me, none of the solutions worked for me.
How can I reset security settings or download security updates?
Thank you.
to reset
http://support.microsoft.com/kb/923737
windows update will update IE
I run Microsoft's application and restored IE but unfortunately it was useless, I am still getting the exact same error.
Thanks for helping.
Did you try as a new local admin user ?
I'm having the exact same issue.
Tried a few different things such as disabling scripts in internet options and running as admin but still no luck.
DId you try in diagnostics mode
http://usa.autodesk.com/getdoc/id=TS13404186
I have the same script error when trying to activate Revit 2013 and AutoCad2013. I have windows 7 and I have tried the diagnostic mode, other user and I don't even use Internet explorer. Is there anything else I can do to to fix this?
Please reply, I really need these programs for my sudies.
