• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Discussion Groups
    Installation & Licensing
    Active Contributor
    where are stored the environment settings ?
    130 Views, 1 Replies
    11-28-2012 08:02 AM
    By environment settings I mean things that are NOT in the cuix.
    For exemple:
    -position, size of properties, design center and tool palette.
    -view settings inside the toolpalettes
    -the fact that all locations are locked
    All of this is to ease a big deployment (80+ people)
    I already found many settings in the registry (HKEY_CURRENT_USER\Software\Autodesk\AutoCAD LT\R18\ACADLT-B001:409\Profiles) and extracted them...
    But it's not working for the a.m. settings.
    Please use plain text.
    Product Support
    Re: where are stored the environment settings ?
    12-03-2012 03:56 PM in reply to: c.dufrene
    This depends on the product but typicaly the settings are located in both the registry and in folders in the user profile. Here is an example
    AutoCAD 2013:
    Reg Keys - HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R19.0
    Folders -
    C:\Users\%username%\AppData\Local\Autodesk\AutoCAD 2013
    C:\Users\%username%\AppData\Roaming\Autodesk\AutoCAD 2013
