Installation & Licensing
visualization file revit on tablet surface pro
8 REPLIES 8
Message 1 of 9
ppesce
1333 Views, 8 Replies
How can I get visualization of revit file on tablet Windows surface Pro 128 Gb, I' ve installated revit 2014 but doesn't start, in other way autocad 2014 get right!
8 REPLIES 8
Message 2 of 9
TravisNave
in reply to: ppesce
I don't understand your problem.  Autodesk products work fine on my Surface Pro.  What issue are you experiencing?
Autodesk Forums:
Message 3 of 9
ppesce
in reply to: TravisNave
I've Building Design Suite  Premium and Revit 2014 on windows 8 tablet surface pro but revit doesn't work, i send you a error file
Message 4 of 9
TravisNave
in reply to: ppesce
And that translates to?
Autodesk Forums:
Message 5 of 9
dembkod
in reply to: ppesce
ppesce,
Hello. If you could translate into English, it may help. I am guessing there may be a corrupt install or a permission problem. Have you uninstalled and reinstalled?
Have you updated your graphics card drivers?
Have you checked the Windows Event Log for any errors?
I would uninstall and trr to reinstall first, and make sure Antivirus is off before you install. It is a good place to start.
Thank you for taking part in our community!
David Dembkoski
Message 6 of 9
ppesce
i send the translation:
Impossible to start the specified application. The configuration of the flanked mode application is not right. To consumption event registry application or use tool line command sxstrace.exe to have more information
Message 7 of 9
TravisNave
in reply to: ppesce
This is a known problem with the Visual C++ files.
Please see this KB article:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=14095878&linkID=9241177
Good Luck!
Autodesk Forums:
Message 8 of 9
ppesce
I've solved unistalling all autodesk programs and reinstalling with the right Visual C + + files,
thank for your support
Message 9 of 9
am_love857
in reply to: ppesce
how can i downlaod revit for tablet ? and any autodesk product?
Administrator Productivity
