Jason it's not the debug log that the SAM is reading. It's a separate
logfile you have to make Flex generate in the adskflex.opt -file. This
file if correctly configured is cumulative and will not overwrite when
the server goes down. The line in the opt -file looks like this:
REPORTLOG +E:\license\reportlog.rl
The + makes it cumulative. This won't help much though. Here's a clip
from the file:
R1*7s(L12g8Oeiy,ZgEO^%v)~m.-~i5lVijiw,yJ?4elIlc5yk,l{J!ki(beKSim}(t(/-
Ggif6t^^%v):ewk&O6OGn@O@OHZZ!Xj
l9-:jki}J!ki(beKSim}(t(_5gi-kLiViji112gyj;1el`i8-?j5j~J!ki(beKSim}(t(w9
ogi.#j'^%v):e|JAE_kVijiE-@*`$IC2gQj;17kap}(t(G1{i-k_(}J)AFgvFR#_kVijiC-
bzK[$yK2g/k=BZgxFj'eltiI1}kNk{J!ki(beKSim}(t(G1giF'$,^%v):ebk&O:Oon}(t(
e/-{i!.:e"K?4FgMSGn9ORO^%v)~mu(_iw,!KYIFgxF$,_kVijiA-.;[$E?2gej)`Zg{F.c
t_k$)s({i$I:e!j&O3O5k<17k%pUdF!jm/-{j_(#K'0FgPSGn9Okd<0
rR$_k$)s(gi[E<0dlBi11n,\.%KqMFgcdT4Pl~3`Tzi
o!K+RFgddl8Dj8FzK0j
ty,ZgEO^%v)4nt(sifjVijiI52gMpXS8O.EZ!Xj
t?O[nXSiW(&5-1>2g8Oeiy,ZgEO^%v)\n`FRS{(t(]$G22g]lS5elDk~(Ai5j~J!ki(beKS
And the price is an annual service charge PER SERVER!
Cheers,
Petri Ahava
CAD-Q Finland
jason martin wrote:
> I wanna say that the full version is around $5k, but I can't confirm (globetrotter used to have prices, I think, because I'm almost
> sure that I've seen it somewhere). I've though about trying to "process" the debug log, yes I know that it plainly says that "this
> log intended for debugging only, blah, blah, blah", but I think it's close enough for what information I would want. The bad thing
> is that it's cleared every time you restart the service, so "historical" usage might be a problem. Opinions??
> jason martin
> frankfurt-short-bruza
> Member of the Autodesk Discussion Forum Moderator Program
> "Charles Prettyman" wrote in message news:C39AAFC2B36CA79E544CD2EDC43E8EAD@in.WebX.maYIadrTaRb...
>>Also, if there is a way to get SAMReport Lite to cough up more informative
>>reports, you could build that into your ASP page, since it also creates HTML
>>output.
>>Is a full versionof SAMReport Expensive? The Globetrotter Website doesn't
>>seem to list prices anywhere.
>>"jason martin" wrote in message
>>news:7823E72A2E107D18D4E142BE42C6994E@in.WebX.maYIadrTaRb...
>>>Thanks Charles.
>>>Yea, generating the html is actually very easy. I've got most of the html
>>"local" version done, I just haven't had time to finish
>>>it (which means I haven't debugged, and I'm somehow leaving the wsh
>>process running when I close).
>>>I'd really like to make it more of an asp page, but I haven't even started
>>looking at that yet. I like the idea of it running as an
>>>asp on the web server because it keeps the lmutil off the user machines
>>(it's not like they can't download it for free, but I really
>>>prefer not "giving" it to them).
>>>jason martin
>>news:3F9106B87FAA1E8B71F02CC02DCB68E1@in.WebX.maYIadrTaRb...
>>>>Jason
>>>>I just tried out the little license checking utility that you posted
>>earlier
>>>>in CF, and it worked fine here. I'm not much of a programmer, but it
>>seems
>>>>to me that you should be able to get it to generate an HTML file fairly
>>>>easily. From there, it probably isn't a huge step to get it to work as
>>part
>>>>of an interanet page.
>>>>Anyway, nice little tool. Thanks for sharing.
