Installation & Licensing
uninstall building design suites
12 REPLIES 12
Message 1 of 13
jdcho
11423 Views, 12 Replies
is there an easy way to uninstall building design suites?  a user messed up their machine and I want to do a clean install of everything.  Couldn't find anything that talks about design suites and I don't want to uninstall each program one at a time.
12 REPLIES 12
Message 2 of 13
TravisNave
in reply to: jdcho
You can try the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Message 3 of 13
emily.xu
in reply to: jdcho
There is no uninstallation tool for BDS,you should follow this solution to clean your autodesk products.
Emily Xu
Product Support
Message 4 of 13
philip.s
in reply to: emily.xu
Just wanted to add here that the only automated suite uninstaller that is currently available pertains to the AutoCAD Design Suite
Message 5 of 13
robincapperw
in reply to: jdcho
The lack of an uninstaller for BDS is not acceptable given the complexity and time requried to do this manually
Robin
Autodesk AEC Collection 2020 - PC: HP Z6 | Win 10 64 | Xeon 3014 | 64 GB ram | Quadro P5000 - Tablet: Surface 3 Pro i5-4300u | Win 10 Ent 1703 64 | 8GB ram - Phone: Samsung S21 Ultra | Android 11
RobiNZ CAD Blog | LinkedIn
Message 6 of 13
DarrenP
in reply to: robincapperw
this is fixed in 2014
autodesk includes an uninstall tool for 2014 products now
DarrenP
Message 7 of 13
paullimapa
in reply to: DarrenP
since there's an uninstall tool in 2014, can't this be ported back to be backwards compatible with 2013, 2012 and etc?
Paul Li
IT Specialist
@The Office
Message 8 of 13
RBG-UK-CAD
in reply to: jdcho
Message 9 of 13
paullimapa
in reply to: RBG-UK-CAD
Thanks for the feedback. But that tool seems to be for Autodesk Design Suite & not Autodesk Building Design Suite.
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales |Exchange App Store
Paul Li
IT Specialist
@The Office
Message 10 of 13
robincapperw
in reply to: paullimapa
I never found one, it was actually quicker to reset the machine (reinstall windows) than manually uninstall the Buliding Design Suite bit by bit. Not a bad thing to do every now and then anyway
Robin
Message 11 of 13
RBG-UK-CAD
i found one for 2015 called psebuninstalltool.exe
See attached
Message 12 of 13
paullimapa
As another poster & myself have already said that since 2014 (which means also 2015), BDSP included an uninstall tool.
What we're looking for is an uninstall tool for older versions of BDSP like for 2012 & 2013.
Paul Li
IT Specialist
@The Office
Administrator Productivity
