• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    *Witkop-Staub, Robin
    unable to save intermittent error
    114 Views, 6 Replies
    01-12-2000 09:39 PM
    I have 4 acad2000 users (all autocad installs are local) sharing files on a
    Novell 5.0 mapped drive. Windows 95 B on Compaq PII 300 networked desktops.
    On occasion they will receive a error stating they cant save because the
    drawing is in use by another session. It creates a *.ac$ file and procedes.
    Sometimes they perform a SAVE AS command to get out of this but it does not
    always work.
    All users have proper rights and access to the mapped drives. No other
    programs give access errors. The problem comes and goes and there are no
    other users in these drawing files. What is causing this error and is there
    a fix.
    Please use plain text.
    *Milana, Jerry
    Re: unable to save intermittent error
    01-14-2000 02:18 PM in reply to: *Witkop-Staub, Robin
    Robin,
    This is a known issue with Netware , you will find lots of postings in this site
    regarding this problem. This problem has been identifyed as being caused by
    some versions of Novell's Client 32. You should contact your Novell support
    resource to obtain the latest version of Client 32 and try it.
    Jerry Milana,
    Autodesk Product Support
    > always work.
    > a fix.
    Re:
    01-17-2000 07:44 PM in reply to: *Witkop-Staub, Robin
    I have been able to dramatically reduce the saving error by changing the
    ISAVEPERCENT variable from 50 to 100. This is going to increase the size of
    our drawings I assume though. I looked up Novell client data and they just
    released a new client32 on 1/13/00. I will download, install, and let you
    know if this helps.
    Jerry Milana wrote in message <387FA09E.95DD3E51@autodesk.com>...
    >Robin,
    site
    by
    support
    >Jerry Milana,
    a
    desktops.
    procedes.
    not
    >> always work.
    there
    >> a fix.
    *Hanson, Tore
    Re:
    01-24-2000 08:23 AM in reply to: *Witkop-Staub, Robin
    Don't believe that it is just a Netware problem. I get the same problem and
    I don't use Netware! I use the MS networking functions. I had the problem in
    Win98 and now in Win98SE (second edition). I was told that I needed to
    update everything, remove all the network cards and then see if I had the
    problem, ya right! I just have to keep renaming the drawing until I'm
    finished a session, then go back and rename the final drawing to the correct
    name....what a hassle, but at least I get to save my changes.
    I did purchase and install Win98SE to see if the problem would dissappear,
    but it didn't. I don't intend to remove the network cards for the sake of
    this bug. If I get paid by Autodesk for my downtime, I will be glad to try
    it. I'm sorry that the problem hasn't been resolved yet!
    Tore Hanson
    news:387FA09E.95DD3E51@autodesk.com...
    > Robin,
    this site
    by
    support
    > Jerry Milana,
    on a
    desktops.
    procedes.
    not
    > > always work.
    no
    there
    > > a fix.
    *Schroeder, Bud
    Re:
    01-25-2000 10:14 PM in reply to: *Witkop-Staub, Robin
    Hi Tore,
    I hit this today... Win98 SE on my DELL Laptop I had saved the file 4 or 5
    times and it was going fine. Then I get a read only message. The only
    difference here was I was working In Word 2000 and not AutoCAD. I have seen
    some strange stuff in 98 SE, but nothing reproducible yet. AutoCAD doesn't
    handle the file locking, the Operating System does. So you may be having
    problems but it is most likely Microsoft here.
    What Jerry is talking about is a very well known problem with the Novell
    Client. I ran nothing but Novell servers for many year and was bit by Novell
    Client problems way too many times;-)...
    Take care.
    Bud
    PS I just ran the live update off of the Microsoft site, so I do have all the
    latest patches on my system.
    > Tore Hanson
    > > Robin,
    > this site
    > by
    > support
    > > Jerry Milana,
    > on a
    > desktops.
    > procedes.
    > not
    > > > always work.
    > no
    > there
    > > > a fix.
    *Hanson, Tore
    Re:
    01-26-2000 05:09 PM in reply to: *Witkop-Staub, Robin
    Thanks for a second opinion. I appreciate knowing this from a "third" party.
    So now I have to find "where" the file locking is handled. I've done "live"
    updates too, but still no change. Win98 is in a constant state of needing an
    update.
    Tore
    Bud Schroeder wrote in message
    news:388E90CB.41BE2AAF@sonic.net...
    > Hi Tore,
    5
    seen
    doesn't
    Novell
    > Take care.
    > Bud
    the
    and
    problem in
    the
    correct
    dissappear,
    of
    try
    > > Tore Hanson
    > > > Robin,
    > > this site
    caused
    > > by
    > > support
    > > > Jerry Milana,
    files
    > > on a
    > > desktops.
    the
    > > procedes.
    does
    > > not
    > > > > always work.
    other
    are
    > > no
    is
    > > there
    > > > > a fix.
    01-26-2000 08:15 PM in reply to: *Witkop-Staub, Robin
    I have installed the new version of novell's client32 (3.2) and set my
    ISAVEPERCENT back to 0. I have been testing for 4 days now with no errors -
    knock on wood...
    Robin Witkop-Staub wrote in message
    <85joci$gfe16@adesknews2.autodesk.com>...
    desktops.
    procedes.
    >always work.
    >a fix.
