Installation & Licensing
unable to install autocad12
0 REPLIES 0
Message 1 of 1
manojkrreddy
335 Views, 0 Replies
here is the installation log file..plz help.
2012/6/24:22:24:09 MANOJ MANOJ-PC === Setup started on MANOJ-PC by MANOJ ===
2012/6/24:22:24:09 MANOJ MANOJ-PC Launch
2012/6/24:22:24:55 MANOJ MANOJ-PC === Setup ended ===
2012/6/24:22:24:10 MANOJ MANOJ-PC === Setup started on MANOJ-PC by MANOJ ===
2012/6/24:22:24:10 MANOJ MANOJ-PC Launch
2012/6/24:22:24:56 MANOJ MANOJ-PC PageOpen LaunchDialog
2012/6/24:22:26:23 MANOJ MANOJ-PC PageOpen LicenseDialog
2012/6/24:22:26:23 MANOJ MANOJ-PC PageOpen ProductSelectionDialog2
2012/6/24:22:26:38 MANOJ MANOJ-PC PageOpen FullProgressDialog
2012/6/24:22:26:38 MANOJ MANOJ-PC Installing Network License Manager: INSTALLDIR="D:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_2012_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/24:22:26:45 MANOJ MANOJ-PC Install Network License Manager Succeeded
2012/6/24:22:26:45 MANOJ MANOJ-PC Installing Autodesk CAD Manager Tools: INSTALLDIR="D:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_2012_English_Win_32bit\" INSTALLDIR="D:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/24:22:26:51 MANOJ MANOJ-PC Install Autodesk CAD Manager Tools Succeeded
2012/6/24:22:26:51 MANOJ MANOJ-PC PageOpen InstallCompleteDialog
2012/6/24:22:27:08 MANOJ MANOJ-PC === Setup ended ===
2012/6/24:22:27:43 MANOJ MANOJ-PC === Setup started on MANOJ-PC by MANOJ ===
2012/6/24:22:27:43 MANOJ MANOJ-PC Launch
2012/6/24:22:27:59 MANOJ MANOJ-PC === Setup ended ===
2012/6/24:22:27:44 MANOJ MANOJ-PC === Setup started on MANOJ-PC by MANOJ ===
2012/6/24:22:27:44 MANOJ MANOJ-PC Launch
2012/6/24:22:27:59 MANOJ MANOJ-PC PageOpen LaunchDialog
2012/6/24:22:28:15 MANOJ MANOJ-PC PageOpen BeginDeploymentDialog
2012/6/24:22:28:49 MANOJ MANOJ-PC PageOpen LaunchDialog
2012/6/24:22:29:08 MANOJ MANOJ-PC PageOpen LicenseDialog
2012/6/24:22:29:56 MANOJ MANOJ-PC PageOpen ProductInfoDialog
2012/6/24:22:32:47 MANOJ MANOJ-PC PageOpen ProductSelectionDialog2
2012/6/24:22:34:05 MANOJ MANOJ-PC PageOpen FullProgressDialog
2012/6/24:22:34:06 MANOJ MANOJ-PC Installing DirectX Runtime: D:\Autodesk\AutoCAD_2012_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/24:22:35:06 MANOJ MANOJ-PC Install DirectX Runtime Succeeded
2012/6/24:22:35:06 MANOJ MANOJ-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_2012_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/24:22:35:39 MANOJ MANOJ-PC Install FaroSDK Failed Failure is ignored, Result=1603
2012/6/24:22:35:39 MANOJ MANOJ-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_2012_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/24:22:36:43 MANOJ MANOJ-PC Install Autodesk Material Library 2012 Succeeded
2012/6/24:22:36:43 MANOJ MANOJ-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_2012_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/24:22:37:59 MANOJ MANOJ-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/6/24:22:38:00 MANOJ MANOJ-PC Installing AutoCAD® 2012: TRANSFORMS="D:\Autodesk\AutoCAD_2012_English_Win_32bit\x86\en-us\acad\acad.mst;D:\Users\MANOJ\AppData\Local\Temp\_AI1A5C.tmp\x86\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="D:\Autodesk\AutoCAD_2012_English_Win_32bit\" INSTALLDIR="D:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/24:22:49:09 MANOJ MANOJ-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2012/6/24:22:51:56 MANOJ MANOJ-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/6/24:22:56:03 MANOJ MANOJ-PC Rollback Autodesk Material Library 2012 Succeeded
2012/6/24:22:56:03 MANOJ MANOJ-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
2012/6/24:22:56:04 MANOJ MANOJ-PC PageOpen InstallCompleteDialog
2012/6/24:23:02:49 MANOJ MANOJ-PC === Setup ended ===
2012/6/25:18:18:24 MANOJ MANOJ-PC === Setup started on MANOJ-PC by MANOJ ===
2012/6/25:18:18:24 MANOJ MANOJ-PC Launch
2012/6/25:18:19:15 MANOJ MANOJ-PC === Setup ended ===
2012/6/25:18:18:25 MANOJ MANOJ-PC === Setup started on MANOJ-PC by MANOJ ===
2012/6/25:18:18:25 MANOJ MANOJ-PC Launch
2012/6/25:18:19:17 MANOJ MANOJ-PC PageOpen LaunchDialog
2012/6/25:18:32:11 MANOJ MANOJ-PC PageOpen LicenseDialog
2012/6/25:18:32:22 MANOJ MANOJ-PC PageOpen ProductInfoDialog
2012/6/25:18:33:33 MANOJ MANOJ-PC PageOpen ProductSelectionDialog2
2012/6/25:18:33:41 MANOJ MANOJ-PC PageOpen FullProgressDialog
2012/6/25:18:33:41 MANOJ MANOJ-PC Installing DirectX Runtime: C:\Autodesk\AutoCAD_2012_English_Win_32bit\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/25:18:34:38 MANOJ MANOJ-PC Install DirectX Runtime Succeeded
2012/6/25:18:34:38 MANOJ MANOJ-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/25:18:34:53 MANOJ MANOJ-PC Install FaroSDK Succeeded
2012/6/25:18:34:53 MANOJ MANOJ-PC Installing Autodesk Material Library 2012: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/25:18:35:38 MANOJ MANOJ-PC Install Autodesk Material Library 2012 Succeeded
2012/6/25:18:35:38 MANOJ MANOJ-PC Installing Autodesk Material Library 2012 - Low Resolution: ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_32bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/25:18:37:07 MANOJ MANOJ-PC Install Autodesk Material Library 2012 - Low Resolution Succeeded
2012/6/25:18:37:09 MANOJ MANOJ-PC Installing AutoCAD® 2012: TRANSFORMS="C:\Autodesk\AutoCAD_2012_English_Win_32bit\x86\en-us\acad\acad.mst;D:\Users\MANOJ\AppData\Local\Temp\_AI5DFB.tmp\x86\acad\acad-standalone.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2012_English_Win_32bit\" INSTALLDIR="D:\Program Files\Autodesk\AutoCAD 2012 - English\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/25:18:45:53 MANOJ MANOJ-PC Install AutoCAD® 2012 Failed Installation aborted, Result=1603
2012/6/25:18:47:42 MANOJ MANOJ-PC Rollback Autodesk Material Library 2012 - Low Resolution Succeeded
2012/6/25:18:50:26 MANOJ MANOJ-PC Rollback Autodesk Material Library 2012 Succeeded
2012/6/25:18:50:28 MANOJ MANOJ-PC Rollback FaroSDK Succeeded
2012/6/25:18:50:28 MANOJ MANOJ-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619
0 REPLIES 0
Administrator Productivity
