unable to install autocad revit structural detailing program student version.
When i installing try to install this program I get the following Error message 1308 Source file not found
for the following files
Autocad structural detailing 2010 english-32bit\x86\asd\en-us\infotainment\acad\infotainent1.xml
Autocad structural detailing 2010 english-32bit\x86\asd\en-us\infotainment\acad\infotainent2.xml
Autocad structural detailing 2010 english-32bit\x86\asd\en-us\infotainment\acad\infotainent3.xml
also it appears to try to install a 32 bit version on a 64 bit machine
I tried down loading twice and downed on a different computer.
i checked the registry and removed each download be each try
i have AMD Phenom 2.8 GHZ and 4 gm memory
windows 7 ultimate
Please try to install 64 bit version of the program on 64 bit OS.
error talks about 32 bit installation.
(assuming you are on 64 bit OS)
i am on a 64 bit machine
it will not let me click the 64 bit version button
I also tried to remove it from all the folders before i tried to reinstall it
also, checked the registry
i have AMD Phenom 2.8 Ghz
4 g Ram
windows 7 Ultimate
more suggestions please
your help is appricated
frank
Please check the system properties to verify the system type as 64 bit
Control panel->System
or please post the screenshot here
Please see attachments for screens
the button will not change
i had my son down load on his computer and copy it the program to disk
I tried clearing my computer again of all autodesk files, registry etc.
reinstall from disk
get same screen as before. i asume if i continue i will get the same error message
any ideas would be appriciated
frank
