this is the install log failure i get everytime i try to install 2013. It says intallation complete, that some of it failed to install...
2013/1/12:12:57:14 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/12:12:57:14 joeyd LAUREN-PC Launch 2013/1/12:12:57:21 joeyd LAUREN-PC === Setup ended ===
2013/1/12:12:57:16 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/12:12:57:16 joeyd LAUREN-PC Launch 2013/1/12:12:57:16 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/12:12:57:16 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/12:12:57:16 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/12:12:57:21 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/12:13:06:54 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/12:13:06:58 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/12:13:07:38 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/12:13:07:42 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/12:13:07:42 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/12:13:08:25 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/12:13:08:29 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/12:13:22:16 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/12:13:22:16 joeyd LAUREN-PC === Setup ended ===
2013/1/12:13:23:43 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/12:13:23:43 joeyd LAUREN-PC Launch 2013/1/12:13:23:43 joeyd LAUREN-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-26576648 /PK 001E1 /student /skipEULA /akamai /auth /sid 2013/1/12:13:24:38 joeyd LAUREN-PC === Setup ended ===
2013/1/12:13:23:45 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/12:13:23:45 joeyd LAUREN-PC Launch 2013/1/12:13:23:45 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/12:13:23:45 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/12:13:23:45 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/12:13:23:46 joeyd LAUREN-PC Download Play SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/12:13:24:38 joeyd LAUREN-PC Download Complete SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/12:13:24:38 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/12:13:29:47 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/12:13:29:47 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/12:13:29:47 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/12:13:29:53 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/12:13:29:55 joeyd LAUREN-PC Download Play DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT... 2013/1/12:13:31:11 joeyd LAUREN-PC Download Complete DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT... 2013/1/12:13:31:11 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/12:13:31:43 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/12:13:31:43 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/13:13:28:00 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:28:00 joeyd LAUREN-PC === Setup ended ===
2013/1/13:13:28:34 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/13:13:28:34 joeyd LAUREN-PC Launch 2013/1/13:13:28:34 joeyd LAUREN-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-26576648 /PK 001E1 /student /skipEULA /akamai /auth /sid 2013/1/13:13:28:36 joeyd LAUREN-PC === Setup ended ===
2013/1/13:13:28:35 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/13:13:28:35 joeyd LAUREN-PC Launch 2013/1/13:13:28:35 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/13:13:28:35 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:28:35 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:28:36 joeyd LAUREN-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/13:13:28:36 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/13:13:28:48 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/13:13:28:48 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/13:13:28:48 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/13:13:29:08 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/13:13:29:08 joeyd LAUREN-PC Download Skipped DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT... 2013/1/13:13:29:08 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/13:13:29:40 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/13:13:29:42 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/13:13:29:54 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:29:54 joeyd LAUREN-PC === Setup ended ===
2013/1/13:13:30:46 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/13:13:30:46 joeyd LAUREN-PC Launch 2013/1/13:13:30:52 joeyd LAUREN-PC === Setup ended ===
2013/1/13:13:30:48 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/13:13:30:48 joeyd LAUREN-PC Launch 2013/1/13:13:30:48 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/13:13:30:48 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:30:48 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:30:51 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/13:13:30:55 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/13:13:30:59 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/13:13:31:32 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/13:13:31:41 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/13:13:31:41 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/13:13:32:12 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/13:13:32:14 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/13:13:32:21 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:32:21 joeyd LAUREN-PC === Setup ended ===
2013/1/13:13:32:54 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/13:13:32:54 joeyd LAUREN-PC Launch 2013/1/13:13:32:57 joeyd LAUREN-PC === Setup ended ===
2013/1/13:13:32:55 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/13:13:32:55 joeyd LAUREN-PC Launch 2013/1/13:13:32:55 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/13:13:32:55 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:32:55 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:32:57 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/13:13:33:09 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/13:13:33:09 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/13:13:33:32 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/13:13:33:32 joeyd LAUREN-PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/13:13:33:35 joeyd LAUREN-PC Install Network License Manager Succeeded 2013/1/13:13:33:35 joeyd LAUREN-PC Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/13:13:33:38 joeyd LAUREN-PC Install Autodesk CAD Manager Tools Succeeded 2013/1/13:13:33:38 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/13:13:34:11 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/13:13:34:13 joeyd LAUREN-PC Rollback Autodesk CAD Manager Tools Succeeded 2013/1/13:13:34:16 joeyd LAUREN-PC Rollback Network License Manager Succeeded 2013/1/13:13:34:16 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/13:13:35:02 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:35:02 joeyd LAUREN-PC === Setup ended ===
2013/1/13:13:51:07 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/13:13:51:07 joeyd LAUREN-PC Launch 2013/1/13:13:51:11 joeyd LAUREN-PC === Setup ended ===
2013/1/13:13:51:07 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/13:13:51:07 joeyd LAUREN-PC Launch 2013/1/13:13:51:08 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/13:13:51:08 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:51:08 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/13:13:51:10 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/13:13:52:44 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/13:13:52:48 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/13:13:53:22 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/13:13:53:28 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/13:13:53:28 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/13:13:53:59 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/18:21:34:21 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:21:34:21 joeyd LAUREN-PC Launch 2013/1/18:21:34:24 joeyd LAUREN-PC === Setup ended ===
2013/1/18:21:34:21 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:21:34:21 joeyd LAUREN-PC Launch 2013/1/18:21:34:21 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:21:34:21 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:21:34:21 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:21:34:25 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:21:34:32 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:21:34:44 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/18:21:35:25 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:21:35:43 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/18:21:35:43 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/18:21:36:15 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/18:21:36:16 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/18:22:28:26 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:28:26 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:28:31 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:28:31 joeyd LAUREN-PC Launch 2013/1/18:22:28:35 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:28:32 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:28:32 joeyd LAUREN-PC Launch 2013/1/18:22:28:32 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:22:28:32 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:28:32 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:28:35 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:28:37 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:22:28:46 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/18:22:29:31 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:22:30:59 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/18:22:30:59 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/18:22:31:30 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/18:22:31:32 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/18:22:38:29 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:38:29 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:40:15 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:40:15 joeyd LAUREN-PC Launch 2013/1/18:22:40:19 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:40:16 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:40:16 joeyd LAUREN-PC Launch 2013/1/18:22:40:16 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:22:40:16 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:40:16 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:40:19 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:40:24 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:22:40:31 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/18:22:42:56 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:22:43:31 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/18:22:43:31 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/18:22:44:01 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/18:22:44:01 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/18:22:44:11 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:44:11 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:45:37 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:45:37 joeyd LAUREN-PC Launch 2013/1/18:22:45:40 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:45:38 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:45:38 joeyd LAUREN-PC Launch 2013/1/18:22:45:38 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:22:45:38 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:45:38 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:45:40 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:45:47 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:22:45:47 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:22:46:02 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/18:22:46:02 joeyd LAUREN-PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/18:22:46:04 joeyd LAUREN-PC Install Network License Manager Succeeded 2013/1/18:22:46:04 joeyd LAUREN-PC Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/18:22:46:07 joeyd LAUREN-PC Install Autodesk CAD Manager Tools Succeeded 2013/1/18:22:46:07 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/18:22:46:38 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/18:22:46:40 joeyd LAUREN-PC Rollback Autodesk CAD Manager Tools Succeeded 2013/1/18:22:46:42 joeyd LAUREN-PC Rollback Network License Manager Succeeded 2013/1/18:22:46:42 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/18:22:48:41 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:48:41 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:48:45 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:48:45 joeyd LAUREN-PC Launch 2013/1/18:22:48:49 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:48:46 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:48:46 joeyd LAUREN-PC Launch 2013/1/18:22:48:46 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:22:48:46 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:48:46 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:48:49 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:49:14 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:22:49:14 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:22:49:17 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/18:22:49:18 joeyd LAUREN-PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/18:22:49:19 joeyd LAUREN-PC Install Network License Manager Succeeded 2013/1/18:22:49:19 joeyd LAUREN-PC Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/18:22:49:21 joeyd LAUREN-PC Install Autodesk CAD Manager Tools Succeeded 2013/1/18:22:49:21 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/18:22:49:28 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:49:28 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:50:31 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:50:31 joeyd LAUREN-PC Launch 2013/1/18:22:50:35 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:50:32 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:50:32 joeyd LAUREN-PC Launch 2013/1/18:22:50:32 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:22:50:32 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:50:32 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:50:34 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:50:39 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:22:50:39 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:22:50:45 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/18:22:50:45 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/18:22:51:17 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/18:22:51:17 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/18:22:52:25 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:52:25 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:52:50 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:52:50 joeyd LAUREN-PC Launch 2013/1/18:22:52:53 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:52:51 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:52:51 joeyd LAUREN-PC Launch 2013/1/18:22:52:51 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:22:52:51 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:52:51 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:52:53 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:52:56 joeyd LAUREN-PC PageOpen BeginDeploymentDialog 2013/1/18:22:53:21 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:53:25 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:22:53:32 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/18:22:54:02 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:22:54:25 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/18:22:54:25 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/18:22:54:57 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/18:22:54:57 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/18:22:55:07 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:55:07 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:56:06 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:56:06 joeyd LAUREN-PC Launch 2013/1/18:22:56:09 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:56:07 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:56:07 joeyd LAUREN-PC Launch 2013/1/18:22:56:07 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:22:56:07 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:56:07 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:56:09 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:56:18 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:22:56:18 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:22:57:13 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/18:22:57:13 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/18:22:57:44 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/18:22:57:44 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/18:22:57:52 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:57:52 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:57:57 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:57:57 joeyd LAUREN-PC Launch 2013/1/18:22:58:00 joeyd LAUREN-PC === Setup ended ===
2013/1/18:22:57:57 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/18:22:57:57 joeyd LAUREN-PC Launch 2013/1/18:22:57:57 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/18:22:57:57 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:57:57 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:58:00 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/18:22:58:03 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/18:22:58:03 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/18:22:58:32 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/18:22:58:32 joeyd LAUREN-PC === Setup ended ===
2013/1/21:16:11:24 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/21:16:11:24 joeyd LAUREN-PC Launch 2013/1/21:16:11:24 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/21:16:11:24 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:16:11:24 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:16:11:59 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:16:11:59 joeyd LAUREN-PC === Setup ended ===
2013/1/21:16:20:10 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/21:16:20:10 joeyd LAUREN-PC Launch 2013/1/21:16:20:14 joeyd LAUREN-PC === Setup ended ===
2013/1/21:16:20:11 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/21:16:20:11 joeyd LAUREN-PC Launch 2013/1/21:16:20:11 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/21:16:20:11 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:16:20:11 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:16:20:15 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/21:16:20:17 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/21:16:20:24 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/21:16:21:01 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/21:16:21:57 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/21:16:21:57 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/21:16:22:30 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/21:16:22:30 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/21:16:23:55 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:16:23:55 joeyd LAUREN-PC === Setup ended ===
2013/1/21:20:37:46 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/21:20:37:46 joeyd LAUREN-PC Launch 2013/1/21:20:37:46 joeyd LAUREN-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-26576648 /PK 001E1 /student /skipEULA /akamai /auth /sid 2013/1/21:20:37:49 joeyd LAUREN-PC === Setup ended ===
2013/1/21:20:37:48 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/21:20:37:48 joeyd LAUREN-PC Launch 2013/1/21:20:37:48 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/21:20:37:48 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:20:37:48 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:20:37:49 joeyd LAUREN-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/21:20:37:49 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/21:20:38:04 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/21:20:38:04 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/21:20:38:04 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/21:20:38:16 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/21:20:38:17 joeyd LAUREN-PC Download Skipped DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT... 2013/1/21:20:38:17 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/21:20:38:52 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/21:20:38:54 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/21:20:39:41 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/21:20:39:41 joeyd LAUREN-PC === Setup ended ===
2013/1/26:11:59:16 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:11:59:16 joeyd LAUREN-PC Launch 2013/1/26:11:59:20 joeyd LAUREN-PC === Setup ended ===
2013/1/26:11:59:16 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:11:59:16 joeyd LAUREN-PC Launch 2013/1/26:11:59:16 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/26:11:59:16 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:11:59:16 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:11:59:20 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:11:59:26 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:11:59:29 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/26:12:00:32 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/26:12:00:36 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/26:12:00:37 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/26:12:01:09 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/26:12:03:07 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:03:07 joeyd LAUREN-PC Launch 2013/1/26:12:03:07 joeyd LAUREN-PC An instance of setup is already running. Only one instance of setup can run at a time.2013/1/26:12:03:15 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:01:09 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/26:12:03:40 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:03:40 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:03:43 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:03:43 joeyd LAUREN-PC Launch 2013/1/26:12:03:47 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:03:44 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:03:44 joeyd LAUREN-PC Launch 2013/1/26:12:03:44 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/26:12:03:44 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:03:44 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:03:47 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:12:03:53 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:12:03:53 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/26:12:04:04 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/26:12:04:05 joeyd LAUREN-PC Installing Network License Manager: ALLUSERS=1 INSTALLDIR="C:\Program Files\Autodesk\Autodesk Network License Manager\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/26:12:04:08 joeyd LAUREN-PC Install Network License Manager Succeeded 2013/1/26:12:04:08 joeyd LAUREN-PC Installing Autodesk CAD Manager Tools: INSTALLDIR="C:\Program Files\Autodesk\Autodesk CAD Manager Tools\" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\AutoCAD_2013_English_Win_64bit\" INSTALLDIR="C:\Program Files\Autodesk\CAD Manager Tools\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/26:12:04:12 joeyd LAUREN-PC Install Autodesk CAD Manager Tools Succeeded 2013/1/26:12:04:12 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/26:12:04:42 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/26:12:04:45 joeyd LAUREN-PC Rollback Autodesk CAD Manager Tools Succeeded 2013/1/26:12:04:46 joeyd LAUREN-PC Rollback Network License Manager Succeeded 2013/1/26:12:04:47 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/26:12:04:57 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:04:57 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:05:00 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:05:00 joeyd LAUREN-PC Launch 2013/1/26:12:05:03 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:05:01 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:05:01 joeyd LAUREN-PC Launch 2013/1/26:12:05:01 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/26:12:05:01 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:05:01 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:05:03 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:12:05:05 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:12:05:05 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/26:12:05:19 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/26:12:05:19 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/26:12:05:50 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/26:12:05:51 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/26:12:06:09 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:06:09 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:06:11 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:06:11 joeyd LAUREN-PC Launch 2013/1/26:12:06:14 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:06:12 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:06:12 joeyd LAUREN-PC Launch 2013/1/26:12:06:12 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/26:12:06:12 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:06:12 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:06:14 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:12:06:17 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:12:06:25 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/26:12:06:56 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/26:12:07:03 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/26:12:07:03 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\AutoCAD_2013_English_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/26:12:07:33 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/26:12:07:34 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/26:12:07:59 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:07:59 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:08:11 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:08:11 joeyd LAUREN-PC Launch 2013/1/26:12:08:14 joeyd LAUREN-PC === Setup ended ===
2013/1/26:12:08:12 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:12:08:12 joeyd LAUREN-PC Launch 2013/1/26:12:08:12 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/26:12:08:12 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:08:12 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:08:14 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:12:08:22 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:12:08:22 joeyd LAUREN-PC === Setup ended ===
2013/1/26:14:11:19 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:14:11:19 joeyd LAUREN-PC Launch 2013/1/26:14:11:19 joeyd LAUREN-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-26576648 /PK 001E1 /student /skipEULA /akamai /auth /sid 2013/1/26:14:11:21 joeyd LAUREN-PC === Setup ended ===
2013/1/26:14:11:20 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:14:11:20 joeyd LAUREN-PC Launch 2013/1/26:14:11:20 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/26:14:11:20 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:14:11:20 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:14:11:20 joeyd LAUREN-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/26:14:11:21 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:14:11:35 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:14:11:35 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/26:14:11:35 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/26:14:16:30 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/26:14:16:30 joeyd LAUREN-PC Download Skipped DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT... 2013/1/26:14:16:30 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/26:14:17:02 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/26:14:17:03 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/26:14:17:32 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:14:17:32 joeyd LAUREN-PC === Setup ended ===
2013/1/26:14:19:34 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:14:19:34 joeyd LAUREN-PC Launch 2013/1/26:14:19:34 joeyd LAUREN-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-26576648 /PK 001E1 /student /skipEULA /akamai /auth /sid 2013/1/26:14:19:36 joeyd LAUREN-PC === Setup ended ===
2013/1/26:14:19:35 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:14:19:35 joeyd LAUREN-PC Launch 2013/1/26:14:19:35 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/26:14:19:35 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:14:19:35 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:14:19:36 joeyd LAUREN-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/26:14:19:36 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:14:19:40 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:14:19:40 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/26:14:20:27 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:14:20:27 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:14:20:36 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:14:20:36 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/26:14:20:37 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/26:14:20:41 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/26:14:20:42 joeyd LAUREN-PC Download Skipped DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT... 2013/1/26:14:20:42 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/26:14:21:14 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/26:14:21:16 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/26:14:33:15 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:14:33:15 joeyd LAUREN-PC === Setup ended ===
2013/1/26:15:34:10 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:15:34:10 joeyd LAUREN-PC Launch 2013/1/26:15:34:10 joeyd LAUREN-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-26576648 /PK 001E1 /student /skipEULA /akamai /auth /sid 2013/1/26:15:34:12 joeyd LAUREN-PC === Setup ended ===
2013/1/26:15:34:11 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/26:15:34:11 joeyd LAUREN-PC Launch 2013/1/26:15:34:11 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/26:15:34:11 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:15:34:11 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/26:15:34:11 joeyd LAUREN-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/26:15:34:12 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/26:15:34:25 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/26:15:34:25 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/26:15:34:25 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/26:15:34:49 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/26:15:34:50 joeyd LAUREN-PC Download Play DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR... 2013/1/26:15:34:57 joeyd LAUREN-PC Download Complete DIRECTX http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DIR... 2013/1/26:15:34:57 joeyd LAUREN-PC Installing DirectX Runtime: C:\Autodesk\WI\AutoCAD 2013\3rdParty\DirectX\DXSETUP.exe /silent 2013/1/26:15:35:29 joeyd LAUREN-PC Install DirectX Runtime Succeeded 2013/1/26:15:35:30 joeyd LAUREN-PC Installing FaroSDK: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/26:15:35:41 joeyd LAUREN-PC Install FaroSDK Succeeded 2013/1/26:15:35:41 joeyd LAUREN-PC Installing Autodesk Content Service: INSTALLMODE=PRIVATE AUTOSTART=0 TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\Tools\snap\ContentService.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/26:15:35:50 joeyd LAUREN-PC Install Autodesk Content Service Succeeded 2013/1/26:15:35:50 joeyd LAUREN-PC Installing Autodesk Content Service Language Pack: ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/26:15:35:56 joeyd LAUREN-PC Install Autodesk Content Service Language Pack Succeeded 2013/1/26:15:35:56 joeyd LAUREN-PC Download Play ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA... 2013/1/26:15:39:26 joeyd LAUREN-PC Download Complete ACAD http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA... 2013/1/26:15:39:26 joeyd LAUREN-PC Installing AutoCAD® 2013: TRANSFORMS="C:\Autodesk\WI\AutoCAD 2013\x64\en-us\acad\acad.mst;C:\Users\joeyd\AppData\Local\Temp\_AI3717.tmp\x64\acad\acad-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="C:\Autodesk\WI\AutoCAD 2013" INSTALLDIR="C:\Program Files\Autodesk\AutoCAD 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2013/1/26:15:41:26 joeyd LAUREN-PC Install AutoCAD® 2013 Succeeded 2013/1/26:15:41:26 joeyd LAUREN-PC Download Play ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA... 2013/1/26:15:43:31 joeyd LAUREN-PC Download Aborted ACAD_en-us http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/ACA... 2013/1/26:15:43:31 joeyd LAUREN-PC Install AutoCAD® 2013 Language Pack Failed Download Failed, Installation aborted, Result=1603 2013/1/26:15:44:37 joeyd LAUREN-PC Rollback AutoCAD® 2013 Succeeded 2013/1/26:15:44:40 joeyd LAUREN-PC Rollback Autodesk Content Service Language Pack Succeeded 2013/1/26:15:44:48 joeyd LAUREN-PC Rollback Autodesk Content Service Succeeded 2013/1/26:15:44:52 joeyd LAUREN-PC Rollback FaroSDK Succeeded 2013/1/26:15:44:52 joeyd LAUREN-PC Rollback DirectX Runtime Failed Failure is ignored, Result=1619 2013/1/27:22:42:17 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/27:22:42:17 joeyd LAUREN-PC Launch 2013/1/27:22:42:17 joeyd LAUREN-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-26576648 /PK 001E1 /student /skipEULA /akamai /auth /sid 2013/1/27:22:42:18 joeyd LAUREN-PC === Setup ended ===
2013/1/27:22:42:17 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/27:22:42:17 joeyd LAUREN-PC Launch 2013/1/27:22:42:17 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/27:22:42:17 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/27:22:42:17 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/27:22:42:18 joeyd LAUREN-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/27:22:42:18 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/27:22:42:30 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/27:22:42:30 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/27:22:42:30 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/27:22:42:40 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/27:22:42:40 joeyd LAUREN-PC Download Skipped DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT... 2013/1/27:22:42:40 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/27:22:43:12 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603 2013/1/27:22:43:13 joeyd LAUREN-PC PageOpen InstallCompleteDialog 2013/1/27:22:44:08 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/27:22:44:08 joeyd LAUREN-PC === Setup ended ===
2013/1/27:22:57:07 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/27:22:57:07 joeyd LAUREN-PC Launch 2013/1/27:22:57:07 joeyd LAUREN-PC CommandLine /url "http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/AutoCAD_2013_English_Win_32_64bit_wi_en-US..." /SN 900-26576648 /PK 001E1 /student /skipEULA /akamai /auth /sid 2013/1/27:22:57:08 joeyd LAUREN-PC === Setup ended ===
2013/1/27:22:57:08 joeyd LAUREN-PC === Setup started on LAUREN-PC by joeyd === 2013/1/27:22:57:08 joeyd LAUREN-PC Launch 2013/1/27:22:57:08 joeyd LAUREN-PC [Error: 1060] The specified service does not exist as an installed service. 2013/1/27:22:57:08 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/27:22:57:08 joeyd LAUREN-PC [Error: 6] The handle is invalid. 2013/1/27:22:57:08 joeyd LAUREN-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/SET... 2013/1/27:22:57:08 joeyd LAUREN-PC PageOpen LaunchDialog 2013/1/27:22:57:19 joeyd LAUREN-PC PageOpen LicenseDialog 2013/1/27:22:57:19 joeyd LAUREN-PC PageOpen ProductInfoDialog 2013/1/27:22:57:19 joeyd LAUREN-PC PageOpen ProductSelectionDialog2 2013/1/27:22:57:28 joeyd LAUREN-PC PageOpen FullProgressDialog 2013/1/27:22:57:28 joeyd LAUREN-PC Download Skipped DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/ACD/WI/{A3548B2A-019B-4D04-AB06-D97A758ED489}/DOT... 2013/1/27:22:57:28 joeyd LAUREN-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\AutoCAD 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q 2013/1/27:22:57:58 joeyd LAUREN-PC Install .NET Framework Runtime 4.0 Failed Installation aborted, Result=1603
for the next time please attach a textfile and don't paste it into the message text (as you can see it's quite long and unstructured).
What I see (hopefully the correct item) is:
And that makes me thinking you either have a problem with permissions or you have a problem with Framework.
Within your installation media go to this folder
and start these two programms (they install the Framework and an update)
NDP40-KB2468871-v2-x64.exe
If that worked then you can retry to start the AutoCAD installation, if not, make a screenshot of what happend and let us know that.
Good luck, - alfred -
Alfred is right.
Your product is failing to install because the prerequiste program required by the installer is newer than the version being installed. Please uninstall the prerequisite program causing the issue and run your installer again. Or install direct as suggested above.
If that doesn't work, .NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
