• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    to install client machine
    99 Views, 2 Replies
    12-05-2012 12:27 AM
    sir i have installed license machine ,till now i cant able to install client machine for autocad ,inventor please guide me
    Please use plain text.
    Product Support
    aaronhai
    Re: to install client machine
    12-05-2012 01:58 AM in reply to: kcet.skret
    Hi kcet.skret,
    (1) Please refer to the below document for License Server setup.
    Refer - How to Configure your Network License Server
    (2) For client setup, you should install the product by selecting Network Option for the installation process. You will be prompted to key in or point to the License Server during the install process.
    (3) Upon completion, simply add the Server Hostname in the Systems Environment Variable.
    Refer - How to specify license servers using the ADSKFLEX_LICENSE_FILE environment variable
    (4) You should be able to launch the product now.
    Other Autodesk Licensing Reference Links:
    - Setting up Your Network License
    - Network Licensing Guide
    Please let u sknow if you need further assistance. Thank you.
    Aaron Hai
    AutodeskCare | Product Support
    TW | PI | YT | BLOG
    If my reply was helpful, please Kudo or Accept as Solution. :smileyhappy:
    *Expert Elite*
    TravisNave
    12-05-2012 07:37 AM in reply to: kcet.skret
    Please post your installation logs for the failed client installs.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
