Installation & Licensing
systemerror:unhandled access violation
12 REPLIES 12
Message 1 of 13
philipp.land
872 Views, 12 Replies
I installed Autocad 2013, but when i want to start i get this error
i allready installed it 2times.
, but it didnt help. Btw i got Windows 8 X64
12 REPLIES 12
Message 2 of 13
TravisNave
in reply to: philipp.land
Welcome to the community.
AutoCAD 2013 is only compatible with Windows 8 after installing SP2.  Please find and download the appropriate service pack here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21764214&linkID=9240618
Hopefully that will get you up and running.
Good Luck!
Autodesk Forums:
Message 3 of 13
philipp.land
in reply to: TravisNave
thank you for your answer, but it didnt help, got the same error just withanother code!
Message 4 of 13
asburyj
Unhandled access and unhandled exception errors can be caused my many different factors. Please try the below solutions, they are the are the most common solutions for this kind of error
1.) Update your video driver to the latest version available from your video card manufacturer.
2.)In your programs and features control panel repair your installation of microsoft .net framework 4.0
(or 4.5)
3.) Uninstall all versions of Microsoft Visual C++ and re-install them. I have provided links below
Microsoft Visual C++ 2005 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=5638
Microsoft Visual C++ 2005 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=18471
Microsoft Visual C++ 2008 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=5582
Microsoft Visual C++ 2008 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=2092
Microsoft Visual C++ 2010 SP1 Redistributable Package (x86)
http://www.microsoft.com/en-us/download/details.aspx?id=8328
Microsoft Visual C++ 2010 SP1 Redistributable Package (x64)
http://www.microsoft.com/en-us/download/details.aspx?id=13523
Jeffry Asbury
Message 5 of 13
TravisNave
It's possible that you have some .NET Framework issues.  This is a common side-effect.  If repairing or reinstalling it does not work, you can try the cleanup tool.
.NET Framework issues can be resolved using the .NET Framework Cleanup Tool. More information about this tool can be found at my discussion thread here:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Good Luck!
Autodesk Forums:
Message 6 of 13
philipp.land
Thank you for your answers, i tried everything and it helped a little bit, the programm starts now, but gets then the another error.
And iam also not sure if i fixxed the .net issue correctly. I tried it with .net framwork cleanup and used it, but after the framework was still installed und i couldnt reinstall. Is there a way to just deinstall it?
Message 7 of 13
asburyj
Sorry I just noticed you are on windows 8. In that case .net framework is a "Feature" of windows. You can turn the feature on and off  by checking and unchecking the box but I don't thnik it accomplishes the same thing as an uninstall/reinstall. The .net framework repair tool is your best bet.
enter image description here
Jeffry Asbury
Message 8 of 13
philipp.land
in reply to: asburyj
tried the repair tool aswell 😕 but it didnt work
Message 9 of 13
asburyj
I'm sorry to say I am not sure what else might be occuring here. If you need to get something done in CAD immediatly I would suggest installing the 30 day trial of AutoCAD 2014.
http://www.autodesk.com/products/autodesk-autocad/free-trial
It was designed to support windows 8 so you are less likely to encounter any problems. If you continue to have problems with even that version it may be time to consider a windows OS re-installation.
Jeffry Asbury
Message 10 of 13
philipp.land
the problem is, that i need the programm for my university and there we work with 2013. I dont how how equal the both programms are! are there big differences?
Message 11 of 13
philipp.land
and even more important for me, are they compatible? so can i work in the university with 2013 and at home with 2014? without problems
Message 12 of 13
dembkod
philipp.land,
Hello. Have you updated your graphics card drivers or turned off hardware acceleration?
1.) Right-click the program icon on your desktop
2.) Click "Properties"
3.) Access the "Shortcut" tab
4.) In the "Target" field, after acad.exe" type a space and then /NOHARDWARE
5.) Click "OK" and retest
This type of error is usually due to install corruption, or possibly an incompatible driver on the system. Sometimes a format of the OS is useful, but it is pretty rare.
Thank you for taking part in our community!
David Dembkoski
Message 13 of 13
sofiarsantos
in reply to: dembkod
this procedure helped me to resolve the first fatal error message that show up to me, but then I got this messages:
Administrator Productivity
