• Industries
  • Products
  • Buy
  • Services & Support
  • Communities
  • Installation & Licensing
    New Member
    starting auto cad 2002 lt
    78 Views, 1 Replies
    10-08-2012 08:27 AM
    Every time I try to start it asks me to register? Then even after I but in all the info it closes
    Please use plain text.
    *Expert Elite*
    TravisNave
    Re: starting auto cad 2002 lt
    10-08-2012 09:26 AM in reply to: larry
    This product is not supported on anything above Windows XP, so that could be your reason if you are trying to install it on a newer computer, especially with SATA drives.
    Travis Nave
    My Expert Contributions to the Discussion Groups:   Send TravisNave a Private Message
    FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files | Disk Space
    Please give Kudos or Accept as Solution  If my post was helpful, please give Kudos and/or mark the Accept as Solution button(s) below. Thank you!
