I'm trying to find an easy method for managing a couple handfuls of stand alone serial numbers. Is there any way a stand alone install can have it's serial number changed? For example, I have ACAD installed via serial # 1 and I would like to change the serial number to serial # 2 and re-authorize it. Is this possible via some txt-based file (ini, cfg, xml, etc.)? My issues is that I have 15 different stand alone serial #s, but I want to be able to create a single network-based install.
If I can't change the serial # after installation, is there a way to keep from needing to supply a serial # when creating the network-based install? This might allow me to enter in the desired serial # during install.
I know the easy answer is to upgrade my licenses to a network managed environment, but I'm trying to save a few $s.
Chris
