Dear all,
I had installed Autodesk Inventor 2011 Pro. in that configuration i had chose server licence correctly, but for Autodesk Mech. 2011 in Configuration i had mistakly choosed stand alone Installation because of that my Inventor works properly but Autodesk Mech. is not picking a licence copy and it showing me Two options one is to go for trial Version or second option is give the licence file or sr. no. , I want to use the server licence for Autodesk Mech. as well , is it possible to switch to server licence insted of going for stand alone or trial without uninstalling my software and reinstalling it,
If any option is open for me please help me.
Walekar Dattaraya P.
Walekar4u@gmail.com
nope you have to uninstall it and reinstall it as a network license
DarrenP
Can i have to uninstaaled all Inventor also for that process or only Autodesk Mech. 2011
Tell me.
Walekar Dattatraya.
Uninstall only AutoCAD Mechanical 2011 and re install with Network option
I had uninstalled AutoCAD Mechanical and run the set up but the Autodesk Mech. option is Disable , I am not able to tick the Autodesk Mechnical 2011 Option.
Walekar Dattatraya P.
Launch Control Panel and ensure AutoCAD Mechanical 2011 is not listed.
Delete AcadM 2011 folder from C:\Program Files\Autodesk
Restart the computer and run the setup. If AcadM 2011 is still disabled, try to download Windows uninstaller and uninstall AutoCAD Mechanical 2011 and verify the issue.
